| larss |
Apr 11 2019, 03:03 AM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
I have been offered a 914/6 tailshift gearbox for my -72 tailshift 914/4, are there any issues in fiitting it in my car?
/Lars S |
| mepstein |
Apr 11 2019, 05:22 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,545 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive.
If it was me, I’d sell the six trans for $$$ and buy a rebuilt side shifter with all the parts needed to convert. |
| larss |
Apr 11 2019, 11:20 AM
Thanks all for responding!
You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive. --- So iIf I switch to a tail cone from a 4 I can still use all the linkage as I have it now (tail shift 4 linkage) on the 6 gearbox. /Lars S |
| dr914@autoatlanta.com |
Apr 11 2019, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
also the six transmission has a different ring gear and pinion to deal with the engine power curve, bad bad bad idea to thy to install it on a four, very bad
Thanks all for responding! You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive. --- So iIf I switch to a tail cone from a 4 I can still use all the linkage as I have it now (tail shift 4 linkage) on the 6 gearbox. /Lars S |
| larss |
Apr 11 2019, 11:53 AM
also the six transmission has a different ring gear and pinion to deal with the engine power curve, bad bad bad idea to thy to install it on a four, very bad Thanks again, no this is no longer likely to happen just want to know what the alternatives would mean. I have a 2056 in my car with 2.0 D-jet, runs nice, should this engines power curve be so far from the 2.0 110hp six that the trans was geared for? /Lars S |
larss 914/6 gearbox in a 914/4? Apr 11 2019, 03:03 AM
rgalla9146 You'll need the 6 linkage from the shifter bac... Apr 11 2019, 05:12 AM
larss
You'll need the 6 linkage from the shifter ba... Apr 11 2019, 05:16 AM
dr914@autoatlanta.com yes
also the six transmission has a different ... Apr 11 2019, 12:06 PM
Krieger The only difference between the two is the linkage... Apr 11 2019, 06:27 AM
jtf914 The tail cover is different and you can't use ... Apr 11 2019, 07:04 AM
rgalla9146 I have to correct myself.
You'd have to c... Apr 11 2019, 07:37 AM
dr914@autoatlanta.com no reason to install it, first of all, having to u... Apr 11 2019, 08:27 AM
SirAndy you can sell the six gearbox to a real six owner f... Apr 11 2019, 11:00 AM
oldie914 Change the nose cone to 914/4 and it will work. I ... Apr 11 2019, 11:52 AM
davep I believe you are mistaken there George. The 914/4... Apr 12 2019, 11:23 AM
dr914@autoatlanta.com Dave you are certainly right, I was thinking of th... Apr 12 2019, 12:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 05:35 PM |
