1970-1914 |
Member ![]() ![]() Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada ![]() |
I ended up picking up a new set of these calipers for almost nothing so I am going to see if I can make an adapter to mount them on my 3" spacing Boge 911 struts.
These are 5.25" bolt spacing and are listed to work with the 911 rotor thickness and diameter. No guarantee this will work but we will see.... ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Contact Flat (Lanner), I think he lives in Fort McMurray now, he's a master at adapting calipers.
He also makes a kickass carb cable linkage kit. http://vdubengineering.com/brake-parts-kits/ |
1970-1914 |
Contact Flat (Lanner), I think he lives in Fort McMurray now, he's a master at adapting calipers. He also makes a kickass carb cable linkage kit. http://vdubengineering.com/brake-parts-kits/ Thanks for the recommendation but I want to try fitting this myself. Barring the steering arm or stock mount physically blocking the caliper placement/offset it should be be pretty straightforward. I have access to pretty much anything required to make a set of adapters (Solidworks, cnc mills/lathes/plasma tables, mig/tig etc) as well as some pretty clever guys. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 12th July 2025 - 11:07 AM |
