> How to Clean your Distributor, Distributor Cleaning
r_towle
post Apr 23 2007, 04:23 PM
Custom Member
Dizzy Cleaning Distributor removal
Hi,
I wanted to pull this out and make a unique thread for it so I dont have to keep typing it..
and now it should be easier to find with the search tool
So, your car is running god, but when it gets hot...its starts to do lots of different stuff, lacks power, wont start when hot, back fired when decel, wont hold idle...
This is not a cure all for everything...it is just something that costs next to nothing and really NEEDS to be done every 30 or so years...damn these cars are old, and the distributors in some have never been removed.
So, a couple of things to remember, you cannot put a distributor back in the car 90 or 180 degrees wrong, unless you also remove the distributor drive gear and put that in wrong also...so stay calm...it will be fine, you can only put a distributor in one way...the right way..its the only way it will fit in the hole and set down all the way...
Keep track of the wires, take pictures so you get the wiring correct when you re-install.
Please clean the motor very well in this area...
Here is my suggestion.
Trust me, it costs less than five cents.
Please pay close attention as you do this so you dont drop anything.
Remove the dist cap
Look at were the vacuum pot is pointing and memorize the location of the distributor.
Now, we are going to remove it.
Take the one or two vacuum lines off the distributor, mark them if there are two, its easy to forget.
Now unplug the FI trigger point, and unplug the lead that goes to the coil.
Loosen the 10 adjuster that allows you to rotate the distributor, and turn the distributor clockwise till you can see the 13mm nut that clamps the distributor down.
Now, go get a good light, some rags, screw driver, popsicle stick..whatever you need.
Clean the whole area around that nut, and around the base of the distibutor so you can eat off of it.
Make sure there is no dirt present.
Loosen the nut, and remove it from the engine bay (trust me, just do it)
Look for the washer that was under the nut and remove it from the engine bay..(again trust me)
Now pull out the distributor, try to remember the current position, or you can twist it back to its permanent location so you only need to remember one visual...then pull it out.
Now its out.
Take it to a clean bench and clean all the rest of the crud off.
Two screws take out the FI trigger points, do that and set them aside.
Take out the screw that holds the condensor, set them aside.
Remove the set of points.
Now if its like mine it has two clamps still screwed in, though I have seen them use one clamp to hold the condensor also..whatever.
Take out the two screws that hold the cap clamps, and notice that they are threaded into the advance plates inside the distributor, take a pic if needed so you orient that plate correctly on the way back in.
There set the screws and clamps aside.
Now there are two plates, hooked to the vacuum advance pot, and they are also joined together, with a very small ball bearing in between.
You want to take these two plates out, clean the shit out of them, clean the ball bearing, and re-grease in between the plates.
There is a some funky old grease in there that actually makes the plates hard to move when it gets hot.
This resistance causes some really odd behaviour, and is a simple fix.
Now, put it all back together, blow all the crap out of the lower areas, and in the FI trigger point area...
Inspect and test the trigger points, but for not, do not replace them.
Put it together, with new grease, not so much that it will splatter when the plates spin, but enough to let them now move freely.
Put it back in the car after you are done.
Word of caution.
Put the distributor back in , it should be the only thing in your hands, and the only thing you focus on for that few seconds, after its in, then and only then reach for the washer and nut that hold it down.
That hole is not easy to fish things out of.
Rich
r_towle
post Nov 28 2015, 09:55 AM
Custom Member
Just put this up as a link in another thread for someone who needed it.
Rmital did a better thread but I could n find it.
He posted pics and everything....for those who cannot read.
ctc911ctc
post Apr 15 2019, 07:09 PM
I want to thank you for putting this up so the "search engines can find it", I search for everything within 914W from Google, found exactly what I was looking for!
The cleaning will start tomorrow!
(IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/pray.gif)
QUOTE(r_towle @ Nov 28 2015, 09:55 AM) *
- Lo-Fi Version Time is now: 2nd April 2026 - 10:06 AM
