Throw out bearing failure, What are the symptoms? |
malcolm2 |
Apr 15 2019, 06:12 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Spoke |
Apr 16 2019, 05:12 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Could a mis-adjusted clutch cable also lead to TOB failure? It would seem if the cable is too tight it would be the same as resting a foot on the clutch pedal.
Mark Henry |
Apr 16 2019, 06:18 AM
Could a mis-adjusted clutch cable also lead to TOB failure? It would seem if the cable is too tight it would be the same as resting a foot on the clutch pedal. Yes it definitely can, the pedal must fully return to the rest position and there must be 1/2"-3/4" play. If there's no play or the the pedal isn't returning all the way the bearing is still engaged and spinning just as fast as the engine. This also would wear on the pressure plate fingers. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:43 AM |
