> Trunk Hinge Bolt Snapped Off!, Major PIA!
oakdalecurtis
post Apr 20 2019, 10:46 AM
Oakdalecurtis
I was prepping my car for the next car show and was lowering the trunk slowly, then BANG! The closed trunk was now popping up about two inches high on the right side. I reopened it slowly and saw that the trunk hinge was no longer attached to the inner fender. The hinge bolt had sheared of cleanly, flush with the inner fender support bracket. I removed the trunk lid, released the torsion bar and disassembled the hinge mechanism. I'm pretty good mechanically, but I don't have
EasyOuts and have never removed a broken bolt. After a few phone calls to local mechanics, I found one that said he could remove the broken stud no problem. I ordered a new bolt from George at AA, and he recommended that I also buy a torsion bar tool. I am glad I took his advice! After the mechanic removed the broken bolt and we installed the hinge mechanism and the new bolt, it took the torsion tool, a crow bar, a ton of pressure, and both of us working together to put the torsion bar back over the hinge pin! Thanks George!
dr914@autoatlanta.com
post Apr 20 2019, 11:07 AM
well thankfully the trunk hinge pivot did not break! A lot easier to tap and clean the threads than weld in a new trunk hinge pivot. Antiseize on the shoulder of the bolt will prevent it from happening again
QUOTE(oakdalecurtis @ Apr 20 2019, 09:46 AM) *
- Lo-Fi Version Time is now: 2nd November 2026 - 03:51 AM
