914-6 air conditioning, Advice on compressor choise |
turboman |
Jul 3 2012, 07:56 AM
Newbie Group: Members Posts: 6 Joined: 22-June 12 From: Montoison France Member No.: 14,589 Region Association: France |
Hi, I am in the process to install an original 914 VPC system in my 914-6.
Like all my projects, I work on a budget. First I bought all the parts about 5 years ago, then I refurbished all parts, (professional cleaning, expansion valve) installed the condenser in the front trunk as designed, temporary installed the evaporator console under the dash, and start the preparation process for the compressor installation. I want the installation to be as close as possible to a factory one. For me, is not an option a compressor under the engine, a serpentine belt or similar. I prefer to work extra time, and reach a perfect end product. I used a double pulley from a 74 911, in order to install the pulley and have space for the dual belts, I have to shave a bit the original engine support and the engine cover (see photo). I fit a 2.2 or 2.4 bracket. So far no problems, the end result looks very nice Now I need to choose the compressor. The York is out of question, due to size and efficiency. My options are a Sanden, a Denso or a Panasonic. Any one fitted with a one groove pulley Not being familiar with the air conditioner compressors, and the way you need to calculate cooling capacity vs cabin volume, I would like to ask help form all of you. 1. Which compressor will suit my needs the best? 2. Which compressor is the smallest one? 3. The best compromise? I will keep all of you posted of the progress on the installation and the need or not of a firewall modification. Thanks Francisco Attached thumbnail(s) Attached image(s) |
Steve |
Apr 21 2019, 07:49 AM
914 Guru Group: Members Posts: 5,600 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I bought an electric compressor for under $1000. https://benling.coowor.com/shop/product-det...09087VFAMP1.htm That and a small evaporator in the console and I’m good to go. I already installed an aftermarket condenser behind the GT cooler. I installed two PMS louvered panels below the condenser and GT oil cooler shroud.
Except for the evaporator all the parts will be in the front trunk. No hoses to the rear of the car. I bought all the parts last year, but rustoration and repaint has pushed this project out for awhile. I already have heat via Ben's 1 5/8" heat exchangers. |
mepstein |
Apr 21 2019, 09:16 AM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I bought an electric compressor for under $1000. https://benling.coowor.com/shop/product-det...09087VFAMP1.htm That and a small evaporator in the console and I’m good to go. I already installed an aftermarket condenser behind the GT cooler. Except for the evaporator all the parts will be in the front trunk. No hoses to the rear of the car. I bought all the parts last year, but rustoration and repaint has pushed this project out for awhile. I already have heat via Ben's 1 5/8" heat exchangers. Well I sure would like to see what our doing. If I could do electric a/c for a third of the premade kit price, I'm in. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 05:38 AM |
