> Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR
Mark Henry
post Apr 21 2019, 09:03 AM
that's what I do!
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing.
I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness.
mb911
post Apr 21 2019, 01:41 PM
Mark,
I think I would be in.. I need something and currently have nothing so this would help.
Mark Henry   Gauging interest...pun intended   Apr 21 2019, 09:03 AM
Mark Henry   The meter works with any fuel, gas, diesel, alcoho...   Apr 21 2019, 09:08 AM
mobymutt   I have interest, although I've pretty much blo...   Apr 21 2019, 09:21 AM
Mark Henry   As I said these come as a kit, I have to solder in...   Apr 21 2019, 09:23 AM
mepstein   I'll take one. Tell me when you want money. Th...   Apr 21 2019, 09:30 AM
Mark Henry   I'll take one. Tell me when you want money. T...   Apr 21 2019, 09:39 AM
Mark Henry   This shows the solder job on the daughter board, I...   Apr 21 2019, 09:45 AM
Mark Henry   The 4.9 LSU connector, 2nd pic black doesn't s...   Apr 21 2019, 09:56 AM
Mark Henry   This is the power and output leads, fuse and holde...   Apr 21 2019, 10:06 AM
jd74914   How much? Is that a 14point7 SLC board?   Apr 21 2019, 10:26 AM
Mark Henry   How much? Is that a 14point7 SLC board? Yes it...   Apr 21 2019, 12:10 PM
jd74914   Yes it's a 14point7 (.com) I thought I said t...   Apr 22 2019, 10:27 AM
Mark Henry   I likely could make each one around $10 cheap...   Apr 21 2019, 12:42 PM
ctc911ctc   Ready to ship yet? I likely could make each ...   May 15 2019, 11:20 AM
mb911   Mark, I think I would be in.. I need something an...   Apr 21 2019, 01:41 PM
Mark Henry   Mark, I think I would be in.. I need something a...   Apr 21 2019, 02:20 PM
mb911   Mark , 1/4" should be perfect. I just did t...   Apr 21 2019, 07:28 PM
Mark Henry   Mark , 1/4" should be perfect. I just did ...   Apr 22 2019, 05:17 AM
tmessenger   I bought one of these for my car a couple of month...   Apr 21 2019, 08:03 PM
mb911   Mark, I had always read 10 to 2 o clock?   Apr 22 2019, 05:35 AM
Mark Henry   Mark, I had always read 10 to 2 o clock? 10 or ...   Apr 22 2019, 11:09 AM
914forme   Dual setup would be my choice if your counting Mar...   Apr 22 2019, 07:53 AM
mepstein   :)   Apr 22 2019, 11:17 AM
mb911   I was just looking at innovates website after I wr...   Apr 22 2019, 11:32 AM
Mark Henry   Maybe I'm wrong or misinformed, wouldn't b...   Apr 22 2019, 12:41 PM
mb911   Maybe I'm wrong or misinformed, wouldn't ...   Apr 22 2019, 02:52 PM
Gary   Mark, I'm in for a setup too, probably a two-h...   Apr 22 2019, 05:59 PM
- Lo-Fi Version Time is now: 19th November 2026 - 03:50 AM
