What to do with foam in rear quarters?, getting rid of seam sealer |
amfab |
Apr 23 2019, 10:12 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
So this past weekend I was using a little torch to heat up—and more than occasionally set on fire—the seam sealer so I could scrape off the big globs of it all over the car. I came to realize that the foam people speak of in the rear corner of the car is just put in there and covered with seam sealer.
How do the cool kids deal with this area when restoring? Thanks -Andrew |
914dave |
Apr 24 2019, 05:44 AM
914 Addict Group: Members Posts: 703 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I used great stuff foam to replace the original. If you don’t reapply the foam, that area created a little shelf where mud and dirt will accumulate. If you don’t reapply it just clean the area about occasionally.
tygaboy |
Apr 24 2019, 07:27 AM
914 Guru Group: Members Posts: 5,302 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I used great stuff foam to replace the original. If you don’t reapply the foam, that area created a little shelf where mud and dirt will accumulate. If you don’t reapply it just clean the area about occasionally. I just did the repair to fix a big rust hole caused by the foam and was concerned about this very thing - the shelf, that is. Good to know folks are able to address this in various ways w/out "refoaming". |
Lo-Fi Version | Time is now: 1st June 2024 - 05:12 AM |
