> Plug wire, spark plugs and dwell, New info on post 24
VaccaRabite
post Apr 18 2019, 04:02 PM
En Garde!
So my car starts bucking again on todays shakedown cruise (and with the PA roads this spring it is REALLY SHAKING!). I pull back home guessing the #3 lead came off again. With the car running I touch the lead pull it off the #3 plug. While I'm doing this the plug wire is shocking the hell out of me!
Like an idiot I stand there looking at it (as it continues to shock the hell out of me) until I drop it and I hear it arcing against something in the engine bay.
I turn off the car and remove the entire lead (I have coil near plug, the lead is only about 6 inches long). Flexing it all over, I can't find ANY breaks in the insulation. these leads are almost brand new, and only have about 200 miles on them. They are very flexible and the insulation seems to be in great shape. The pulse was jumping through the insulation on the wire and arcing against the powdercoated #3 intake runner, causing the bucking. The coil pack is certainly strong!
I moved the wire as far as I could from the intake runner (the pack is bolted right next to the intake runners, so I can only move it so far) and the car ran flawlessly. I went on a 30 minute drive and it was AWESOME.
So... what next. On a wet day its going to be arcing everywhere. I've sat through that ride before. Maybe make new leads with thicker plug wires? Do I need spiral wound?
@mcmark
@spoke
Spoke
post Apr 24 2019, 06:31 PM
Jerry
Are there specified wires to use with the high power coils? Seems like your wires are not a good fit for the coil.
VaccaRabite   Plug wire, spark plugs and dwell   Apr 18 2019, 04:02 PM
windforfun   Your plug wire insulation is starting to conduct d...   Apr 18 2019, 04:35 PM
fixer34   Your plug wire insulation is starting to conduct ...   Apr 18 2019, 05:12 PM
rudedude   Can you use copper core wires with microsquirt?   Apr 18 2019, 05:59 PM
steuspeed   Try running the car in your garage with all the wi...   Apr 18 2019, 09:11 PM
porschetub   Try running the car in your garage with all the w...   Apr 19 2019, 12:12 AM
bdstone914   @VaccaRabite What brand wires are you using? I h...   Apr 19 2019, 08:26 AM
VaccaRabite   I’m not using stock wires. I think I have ever...   Apr 19 2019, 11:38 AM
rhodyguy   Wet day? Are the rain tray, funnels and tubes in p...   Apr 19 2019, 04:29 PM
Mark Henry   High power coils? :D They pack a huge jolt, the ...   Apr 19 2019, 08:39 PM
Mikey914   I'd be suspect of the ran tray.   Apr 19 2019, 08:50 PM
VaccaRabite   High power coil packs, one per cylinder, with abou...   Apr 21 2019, 08:18 AM
JamesM   Given you are running Megasquirt, I am wondering i...   Apr 29 2019, 11:30 PM
VaccaRabite   I may have this figured out. maybe. I think the h...   Apr 24 2019, 06:17 PM
Spoke   Are there specified wires to use with the high pow...   Apr 24 2019, 06:31 PM
VaccaRabite   Are there specified wires to use with the high po...   Apr 25 2019, 09:04 AM
JamesM   Just confirmed the MS hardware manual itself was u...   Apr 29 2019, 11:47 PM
VaccaRabite   Just confirmed the MS hardware manual itself was ...   Apr 30 2019, 08:49 AM
infraredcalvin   Why not heed the good advice here and get some new...   Apr 24 2019, 10:57 PM
McMark   They're 1997-2004 Corvette wires. :thumbsup:   Apr 29 2019, 07:42 AM
McMark   They're LS2 style coils. I think the LS1 vs L...   Apr 30 2019, 09:36 AM
JamesM   Dwell recommendation in the MS Manual was lowered ...   Apr 30 2019, 10:17 AM
Rand   Sometimes it feels like we try to do too much to t...   Apr 30 2019, 10:58 AM
VaccaRabite   So a bunch of things have been coming to mind late...   May 13 2019, 12:04 PM
Frank S   Hi Zach, with Megasquirt I think you should use t...   May 22 2019, 04:04 PM
VaccaRabite   Hi Zach, with Megasquirt I think you should use ...   May 23 2019, 07:14 AM
Frank S   Hi Zach, with Megasquirt I think you should use...   May 23 2019, 03:22 PM
crash914   I am running around 4ms on my coils. 2ms spark du...   May 13 2019, 04:19 PM
VaccaRabite   The new plugs came in today. Hopefully I’ll be a...   May 15 2019, 07:02 PM
VaccaRabite   The BP5ES plugs came in last week. The Magnecore w...   May 21 2019, 07:22 PM
crash914   :Qarl: :trophy:   May 22 2019, 07:04 AM
VaccaRabite   Magnecore is shipping out two new wires today. I k...   May 22 2019, 11:58 AM
crash914   not to rain on the party, but I seem to remember s...   May 22 2019, 03:00 PM
crash914   Yes, R is the resistor version. I think the magni...   May 23 2019, 07:17 AM
VaccaRabite   Yes, R is the resistor version. I think the magn...   May 23 2019, 07:40 AM
VaccaRabite   After the lightning, thunder, hail and a possible ...   May 23 2019, 08:39 PM
VaccaRabite   I talked to Steve at Aircooled Racing, and on Tues...   May 25 2019, 05:29 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:53 AM
