Just want a confirmation on power at relay (4-pin) #1 and #3 |
Downerman |
Apr 23 2019, 07:16 PM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
So just to be clear. With the Key on.... On the white four connector (Pulled off) on the relay board, Pins I and III. I have 12V+ which means I'm carrying and confirmed 12V+ at the ECU plug on pins 16 and 24 from white 4 connector pin I . In addition Pin 19 on the ECU also has 12V+ from white 4 connector pin III - WITH KEY ON.
Whats happening is I'm not getting a ground from pin 19 ECU back to 4 wire connector on relay board, number III, to pin 86 of the fuel pump relay, as to flip the relay and give me that 2 second pop of the fuel pump. If I take a small wire on the fuel pump relay #86 and ground it I have power on main cabin connector/Relay board pin 13...AKA fuel pump. All relays tested (headlight trick). Using one of the docs on Jeff's site "Porsche 914 Fuel Pump Troubleshooting" and I fail #12 which tells me I have a faulty ECU. Mine was beat... car was a basket case and now fully restored. Got a used one and same issue. Continuity is perfect everywhere - New Bowsley wiring harness (Engine area). I will spare your the other 21 steps but I pass them all except power to the dang Fuel Pump....cuz #87 never get's the signal from III Here's #12: 12 Test: ECU control circuit Key off:Test continuity from Pin III on white 4 pin connector plug at Relay Board to ground (white plug harness un plugged from Relay Board. ECU harness plugged into ECU). Key on: Continuity to ground for 1.5 seconds = good ECU control cuircuit. Key on: No continuity to ground for 1.5 seconds = faulty ECU control cuircuit (The ECU grounds Pin III of the white 4 pin connector on the Relay Board to run the fuel pump for 1.5 sec. at key on) I'm just trying to understand why I have 12V on III with key on. Which means 12V to pin 19 ECU and I don't want to fry something. Dave |
SirAndy |
Apr 23 2019, 08:59 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you jumper the pin to ground like in the image below (red wire for ground, i know, i know) and your fuel pump runs with the key on then your problem is either your FI brain or the harness connecting the brain to the relay board.
The FI brains rarely die but it does happen ... (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/specs/SirAndyCarbFuelPumpRelay_files/FuelPumpWireEnable.jpg) |
Downerman |
Apr 24 2019, 10:11 AM
If you jumper the pin to ground like in the image below (red wire for ground, i know, i know) and your fuel pump runs with the key on then your problem is either your FI brain or the harness connecting the brain to the relay board. The FI brains rarely die but it does happen ... (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/specs/SirAndyCarbFuelPumpRelay_files/FuelPumpWireEnable.jpg) Yes indeed. that's what it does. So on that pin III of the relay board, it's cool for there to be 12V with key on then? Only reason I ask is because in the troubleshooting doc mentioned in the original post, they mention power only at 16 and 24 of the ECU. With 12V at III on the relay I then of course have 12V at 19 as well on that ECU connector. Just checking. Dave |
SirAndy |
Apr 24 2019, 11:35 AM
So on that pin III of the relay board, it's cool for there to be 12V with key on then? No! That's a ground, if that had 12V hooking it straight up to the chassis would let a lot of smoke out. It is the ground for the fuel pump relay, which is normally controlled by the FI brain. (IMG:style_emoticons/default/smash.gif) |
Downerman |
Apr 24 2019, 08:27 PM
So on that pin III of the relay board, it's cool for there to be 12V with key on then? No! That's a ground, if that had 12V hooking it straight up to the chassis would let a lot of smoke out. It is the ground for the fuel pump relay, which is normally controlled by the FI brain. (IMG:style_emoticons/default/smash.gif) Exactly..... this is why I posted. Did not make sense to me but I have 12V at III on the 4 post on relay board with the key on. So looking at the schematic, III connects to 86 on the Fuel Pump relay. That's it..... so my four wire harness from those roman numbered plug that goes to the ECU is unplugged as right now 12V on III then pin 19 of the ECU cannot be good. For power to be on 86 and III it has to be either my connections under the relay board are making contact with maybe (I), which has 12V and powers the ECU OR pin 30 or 85 on the actual fuel pump relay are somehow making it's way to 86 via the relay which should not be the case....I think Funny thing is they test out on the headlights. Im baffled but will pull the relay board tomorrow and check that out, if good I'm going to apply 12V to 30 with the relay only (in my hand) and see if power if somehow getting to 86, if not apply 12V to 85 and same test. RATS!! |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:41 PM |
