Just want a confirmation on power at relay (4-pin) #1 and #3 |
Downerman |
Apr 23 2019, 07:16 PM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
So just to be clear. With the Key on.... On the white four connector (Pulled off) on the relay board, Pins I and III. I have 12V+ which means I'm carrying and confirmed 12V+ at the ECU plug on pins 16 and 24 from white 4 connector pin I . In addition Pin 19 on the ECU also has 12V+ from white 4 connector pin III - WITH KEY ON.
Whats happening is I'm not getting a ground from pin 19 ECU back to 4 wire connector on relay board, number III, to pin 86 of the fuel pump relay, as to flip the relay and give me that 2 second pop of the fuel pump. If I take a small wire on the fuel pump relay #86 and ground it I have power on main cabin connector/Relay board pin 13...AKA fuel pump. All relays tested (headlight trick). Using one of the docs on Jeff's site "Porsche 914 Fuel Pump Troubleshooting" and I fail #12 which tells me I have a faulty ECU. Mine was beat... car was a basket case and now fully restored. Got a used one and same issue. Continuity is perfect everywhere - New Bowsley wiring harness (Engine area). I will spare your the other 21 steps but I pass them all except power to the dang Fuel Pump....cuz #87 never get's the signal from III Here's #12: 12 Test: ECU control circuit Key off:Test continuity from Pin III on white 4 pin connector plug at Relay Board to ground (white plug harness un plugged from Relay Board. ECU harness plugged into ECU). Key on: Continuity to ground for 1.5 seconds = good ECU control cuircuit. Key on: No continuity to ground for 1.5 seconds = faulty ECU control cuircuit (The ECU grounds Pin III of the white 4 pin connector on the Relay Board to run the fuel pump for 1.5 sec. at key on) I'm just trying to understand why I have 12V on III with key on. Which means 12V to pin 19 ECU and I don't want to fry something. Dave |
SirAndy |
Apr 24 2019, 09:05 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Scratch that, looks like III is connected to 86, not 85 ...
(IMG:style_emoticons/default/unsure.gif) Attached thumbnail(s) |
SirAndy |
Apr 24 2019, 09:21 PM
Scratch that, looks like III is connected to 86, not 85 ... (IMG:style_emoticons/default/unsure.gif) So it looks like for your car the trigger (12V) is on III and the ground is on I which is flipped from what i had on my car ('70) when i took the image of my relay board. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:28 PM |
