| Tdskip |
Apr 26 2019, 08:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Looking to learn more about our engines, I've found rebuild guides to be a great resources on some of my other cars.
Is there a go-to source for these you can recommend? Thanks! |
| bbrock |
Apr 26 2019, 11:17 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Just a quick word as someone who has used both Haynes and Tom Wilson's books to rebuild engines. The Haynes is barely adequate to get the job done and is missing some stuff that you may regret not knowing later (like reusing old valves might grenade your engine (IMG:style_emoticons/default/headbang.gif) ). Wilson's book is WAY better but lacks some information I've learned from this group about things that contribute to a quality build. Things like decking the case to make sure cylinder registers are even and perpendicular to the crank, and cc'ing heads for getting the compression ratio you want when setting deck height.
I'm not knocking those books. They are great (especially Wilson's book). I just wanted to share my experience of what was missing that I wish I had known. |
| Superhawk996 |
Apr 26 2019, 11:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,944 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Just a quick word as someone who has used both Haynes and Tom Wilson's books to rebuild engines. The Haynes is barely adequate to get the job done and is missing some stuff that you may regret not knowing later (like reusing old valves might grenade your engine (IMG:style_emoticons/default/headbang.gif) ). Wilson's book is WAY better but lacks some information I've learned from this group about things that contribute to a quality build. Things like decking the case to make sure cylinder registers are even and perpendicular to the crank, and cc'ing heads for getting the compression ratio you want when setting deck height. I'm not knocking those books. They are great (especially Wilson's book). I just wanted to share my experience of what was missing that I wish I had known. Agree - recommend both books. However, remember VW's are notoriously robust engines. The points you make differentiate a great rebuild from an average one. I used both books referenced when I rebuilt my 1.7L to a 1.9L back in early 90' or 91' and didn't put in the attention to detail ( like decking the case, line boring, etc) and my engine went about 80,000 miles with no issues. Tough little buggers! (IMG:style_emoticons/default/aktion035.gif) I had a early 70's VW bug (flat windshield) with a type 1 engine. Bought it for $50. After a few months of owning and driving it, at the gas station I noticed a huge puddle of oil had formed under it. Looked under it. No source of oil leakage. What the heck? Started it and then looked under it. One of the cylinders was moving back and forth and when it moved out from the case, oil was leaking like mad. Popped off the valve cover, tightened the bottom four cylinder head nuts. The top 4 can't be reached without pulling the tin so I had no choice but to leave them. Being poor, in college, and lacking a place to properly fix it, I drove it several thousand miles with only the bottom 4 bolts tight. No more oil leaks. down on power some but it ran pretty darn good for about a year before I finally dropped the engine. Even then I just tightened up the upper head nuts and then ran it another couple thousand miles before I finally sold it for $75.00 to a guy that was using it for a sand rail donor. Moral of the story - tough little buggers! (IMG:style_emoticons/default/lol-2.gif) |
Tdskip Best type 4 engine rebuild book or guide? Apr 26 2019, 08:02 AM
Beebo Kanelle Mr. Raby's "Type 4 Rebuild DVD" is a... Apr 26 2019, 08:12 AM
JOEPROPER
Mr. Raby's "Type 4 Rebuild DVD" is ... Apr 26 2019, 09:13 AM
mgphoto Wilson VW engine rebuild book is great, a lot of t... Apr 26 2019, 09:47 AM
914Sixer If you want a book that will really give you all t... Apr 26 2019, 09:49 AM
maf914 In the pre internet days I rebuilt my Type 4 engin... Apr 26 2019, 09:58 AM
maf914 I wonder why my attachments stacked horizontally a... Apr 26 2019, 10:00 AM
Tdskip Thanks gentlemen! Apr 26 2019, 10:44 AM
cashiersjm Does Jake Raby still sell the video or where can i... Apr 26 2019, 11:10 AM
rhodyguy Bug Me Video. Apr 26 2019, 11:12 AM
bbrock
Agree - recommend both books. However, remember ... Apr 26 2019, 02:48 PM
Dave_Darling They're all good, but none is perfect. If not... Apr 26 2019, 11:56 AM
Tdskip Ordered Wilson’s book, should make for some good... Apr 27 2019, 06:16 AM
fixer34 Back in my VW days (late 60's/early 70's) ... Apr 27 2019, 11:21 AM
Archie
Back in my VW days (late 60's/early 70's)... May 23 2019, 11:57 AM
settador Wilson's book, John Muir's idiot guide, an... Apr 28 2019, 12:05 PM
Tjmrfe
Wilson's book, John Muir's idiot guide, a... May 24 2019, 09:34 PM
Jake Raby I've contemplated doing a new T4 rebuild video... May 23 2019, 10:10 AM
I've contemplated doing a new T4 rebuild vide... May 23 2019, 11:37 AM
Beebo Kanelle
I've contemplated doing a new T4 rebuild vide... May 23 2019, 12:25 PM
fiacra
I've contemplated doing a new T4 rebuild vide... May 25 2019, 11:18 AM
doug_b_928 I purchased, and plan to use, your video. It woul... May 23 2019, 10:21 AM
Tdskip I’d order an updated version too - I think quite... May 23 2019, 11:18 AM
yeahmag @Jake Raby I'd totally buy an updated one too.... May 23 2019, 12:16 PM
Jake Raby If I decide to do it, I’ll make sure to let you ... May 24 2019, 05:15 PM
If I decide to do it, I’ll make sure to let you... May 24 2019, 05:38 PM
Pearl-in-the-SEA
If I decide to do it, I’ll make sure to let you... Jul 13 2026, 12:15 AM
914-Kazoo The three best sources for Type 4 engine rebuild a... Feb 14 2022, 07:59 PM
Al Meredith I've used Wilson's book for years and it i... Feb 15 2022, 09:51 AM
friethmiller @Jake Raby - I purchased/watched your "20 yea... Feb 15 2022, 10:27 AM
930cabman I have the Wilson, Clymer, Haynes and the factory ... Feb 15 2022, 12:12 PM
mihai914
I have the Wilson, Clymer, Haynes and the factory... Feb 15 2022, 12:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2026 - 04:45 AM |
