| Pdr1787 |
Apr 2 2019, 12:15 AM
Sneaky Pete ![]() ![]() Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
Here are a bunch of misc. parts for sale. for asking price or better offer
Spark plug wires 8mm ...... 60 *Sold* Original belt restraints ( non retractable )...... 50 *Sold* Rocker-arm hardware (Shaft/springs/nuts/bolts/washers)...... 50 *Sold* Outside door handle ..... 50 *Sold* Speaker cover and speaker ( Driver and Passenger side) ...... 100 Heat exchanger elbow .... 50 Heater control valve flap box ....... 50 Clutch release bearing and fork ...... 150 70-72 complete linkage 80 *Sold* Sideshift linkage rod firewall to transmission...... 150 *Sold* Heater blower fan assembly..... 70 70-72 engine motor mount cross bar...... 50 Foot well foam insert ....... 35 Arm rest pocket and lid cover....... 50 Valve cover pair ........ 60 Shifter assembly ...... 100 *Sold* Shift rod coupler 73-76..... 60 w/bolt/screw.....80 *Sold* Motor support bracket 70-72........ 50 Motor mounts...... pair 40 Clutch cable deflection roller and reverse bracket.......40 *Sold* 2.0l cylinders 4 ............ 180 *Sold* Thermostat...... 80 1.7l ecu Works ....... 80 1.7 rods .... 40 Bosch 1.7distributor with vacuum advance..... 100 Hydraulic lifters 1.7 ......80 Vacuum pressure regulator ...... 80 Porsche valve springs full set 90110590150 ...... 140 Bosch starter .......... 140 Bosch 12volt coil ......50 Bosch 009 chrome .........90 Attached thumbnail(s) |
| Chi-town |
Apr 27 2019, 11:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
They're 2.0 bus heads
Pdr1787 Misc 914 parts Apr 2 2019, 12:15 AM
Chi-town Open to offers? I could always use a spare 73-76 s... Apr 2 2019, 12:56 AM
Pdr1787 I am open to offers as well. shoot me a reasonable... Apr 2 2019, 12:25 PM
Pdr1787 Bump Apr 4 2019, 12:47 PM
racingredsc What do the heads fit? I need some for '74 2.... Apr 12 2019, 10:54 AM
Pdr1787
What do the heads fit? I need some for '74 2... Apr 13 2019, 10:06 PM
Pdr1787
What do the heads fit? I need some for '74 ... Apr 15 2019, 05:57 AM
Pdr1787
What do the heads fit? I need some for '74 ... Apr 15 2019, 05:58 AM
forrestkhaag Are the speakers spoken for? And, what condition ... Apr 13 2019, 09:06 AM
Pdr1787
Are the speakers spoken for? And, what condition... Apr 13 2019, 10:09 PM
Pdr1787
Are the speakers spoken for? And, what conditio... Apr 15 2019, 06:00 AM
Pdr1787
Are the speakers spoken for? And, what conditio... Apr 15 2019, 06:01 AM
rasam PM sent for the thermostat. Apr 14 2019, 12:26 AM
Pdr1787 Here a closer picture of the door handle Apr 15 2019, 06:02 AM
racingredsc I'll take the heads if the only problem is the... Apr 16 2019, 12:29 PM
carl k Are those modified 1.7/1.8 heads? I see the four ... Apr 16 2019, 12:47 PM
Pdr1787
Are those modified 1.7/1.8 heads? I see the four... Apr 16 2019, 02:35 PM
bdstone914
Are those modified 1.7/1.8 heads? I see the fou... Apr 27 2019, 08:52 AM
Pdr1787 Bump :bump: Apr 24 2019, 04:06 PM
dl5494 interested in the release bearing and fork as well... May 1 2019, 07:26 AM
Dutchy4U I need cooling fan wheel in pic
are all vins there... May 1 2019, 07:00 PM
dan123 how much for the cooling fan?
also, can you pls po... May 15 2019, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th August 2026 - 09:42 PM |
