Slotting inner trailing arm mount |
yeahmag |
Apr 29 2019, 03:54 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Let me start out by saying I think too much... With that out of the way, I'm wondering what the viability is of slotting the inner trailing arm mount to lower it, giving me more static camber. Here's the idea:
* Small slot of inner ear * 8mm "elevator" with welded tab to control the location of the inner mount prior to tightening the bolt. * Switch from the RSR Teflon bushings to monoballs and custom pivot shafts to allow for the increased angle Nuts or brilliant? I'm at something like 2.4 and would like to see 3+ if I could. Car is already pretty much in the weeds... -Aaron |
Superhawk996 |
Apr 29 2019, 04:22 PM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Two other thoughts:
1) Have you measured your camber vs. rear bump steer already. Do you know if increasing camber will improve or degrade your rear bump steer behavior? 2) Maybe would work if you machined some sort of cam arrangement to allow for adjustment yet limit uncontrolled movement in the slot. Still a bit iffy and if you're going to that trouble, why not just raise the outer suspension console? |
Lo-Fi Version | Time is now: 8th June 2024 - 10:15 AM |
