> Subaru Conversion Won't Idle
turnaround89
post Apr 29 2019, 06:14 PM
Hi everyone, so December 2018 was the first time I got to hear the WRX STi motor I purchased run. It ran rough because the intake wasn't connected, hardly any sensors hooked up, etc. However, it ran and that made me happy knowing my investment wasn't useless.
The engine that was purchased is supposed to be a subaru wrx gc8 sti v4 turbo ej20
Cut to a few months later, now I have all the required sensors (MAF, purge solenoid, ignitor, etc) that I was missing purchased and hooked up. Vacuum hoses hooked up and I thought now the engine should run and idle beautifully. Nope, it will fire and run for maybe 3 seconds then shut off. Check out the video in the link.
Subaru Engine Video
The only thing I dont have hooked up are to the non-pressure side of the intake. I tried plugging these holes today and the car did t idle any better. Now, I need to find a permanent solution to these holes, but I swear the engine is running worse now with everything hooked up then in December with nothing hooked up.
Any ideas where I could start?
I was thinking fuel pressure and timing would be my next step. In the video you can hear the fuel pump prime the system before the engine kicks over.
The wiring harness was sent out to iwire services to be redone and that appears to be functioning properly.
Thank you everyone for your help.
turnaround89
post Apr 30 2019, 08:11 PM
Yes, the speed sensor is hooked up. When the ECU wiring was cleaned up I had to purchase a new speed sensor. The stock speed sensor was mechanical, the new one is electrical.
As for sensors boost, barometric pressure, and I believe purge control solenoid are all in the image below. The last image is the diagram I used to hook up all the boost/vacuum hoses.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1556676714.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1556676715.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/static.opposedforces.com-9067-1556676716.3.png)
Ignore the mess of hoses, it will all be cleaned up once the engine is running properly. Just getting everything together
As always, thank you to everyone!
turnaround89   Subaru Conversion Won't Idle   Apr 29 2019, 06:14 PM
904svo   Just a WAG, Make sure the MAF is installed correct...   Apr 29 2019, 06:31 PM
Chi-town   You need to have everything connected on vacuum an...   Apr 29 2019, 07:03 PM
turnaround89   One of my concerns was if I got the correct MAF se...   Apr 29 2019, 08:33 PM
Costa05   Just a thought here. My mazda started doing the sa...   Apr 29 2019, 09:05 PM
Chi-town   The factory bypass valve cannot be vented to atmos...   Apr 29 2019, 09:39 PM
falcor75   Is there any immobilizer in the ECU that you need ...   Apr 29 2019, 09:43 PM
turnaround89   I dont believe there is an immobilizer. I can hit...   Apr 29 2019, 10:04 PM
pploco   The PCV vents with filters on shouldn't cause ...   Apr 30 2019, 12:26 AM
lierofox   Mine's the exact same EJ20K engine for my swap...   Apr 30 2019, 01:39 AM
Chi-town   An aftermarket bypass valve can be vented to atmos...   Apr 30 2019, 07:15 AM
turnaround89   You guys are the best! Greatly appreciate the...   Apr 30 2019, 04:16 PM
zipedadoo   Do you have the speed sensor hooked up? My ej22 ra...   Apr 30 2019, 05:44 PM
Chi-town   Stock BOV needs a little but of vacuum on the back...   Apr 30 2019, 07:15 PM
turnaround89   Yes, the speed sensor is hooked up. When the ECU ...   Apr 30 2019, 08:11 PM
lierofox   I ended up getting an aftermarket silicone intake ...   May 1 2019, 11:08 AM
pploco   I ended up getting an aftermarket silicone intake...   May 1 2019, 09:12 PM
turnaround89   Hi again everyone, So I finally have the bypass v...   Aug 30 2019, 04:40 PM
Chi-town   Pull the idle air control motor off and watch it a...   Aug 30 2019, 05:36 PM
904svo   If you don't have a program to check your engi...   Aug 30 2019, 08:12 PM
Chi-town   ∆ keep in mind it only works with older laptops ...   Aug 30 2019, 09:10 PM
904svo   ∆ keep in mind it only works with older laptops...   Aug 31 2019, 07:26 AM
76-914   ∆ keep in mind it only works with older laptop...   Aug 31 2019, 08:58 AM
turnaround89   Ill look into the idle air control valve today and...   Aug 31 2019, 08:37 AM
turnaround89   No worries 76-914 It appears the idle air control...   Aug 31 2019, 12:44 PM
turnaround89   I was messing around a bit with the engine today a...   Sep 1 2019, 02:25 PM
- Lo-Fi Version Time is now: 5th September 2025 - 08:07 AM
