turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Hi everyone, so December 2018 was the first time I got to hear the WRX STi motor I purchased run. It ran rough because the intake wasn't connected, hardly any sensors hooked up, etc. However, it ran and that made me happy knowing my investment wasn't useless.
The engine that was purchased is supposed to be a subaru wrx gc8 sti v4 turbo ej20 Cut to a few months later, now I have all the required sensors (MAF, purge solenoid, ignitor, etc) that I was missing purchased and hooked up. Vacuum hoses hooked up and I thought now the engine should run and idle beautifully. Nope, it will fire and run for maybe 3 seconds then shut off. Check out the video in the link. Subaru Engine Video The only thing I dont have hooked up are to the non-pressure side of the intake. I tried plugging these holes today and the car did t idle any better. Now, I need to find a permanent solution to these holes, but I swear the engine is running worse now with everything hooked up then in December with nothing hooked up. Any ideas where I could start? I was thinking fuel pressure and timing would be my next step. In the video you can hear the fuel pump prime the system before the engine kicks over. The wiring harness was sent out to iwire services to be redone and that appears to be functioning properly. Thank you everyone for your help. |
lierofox |
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California ![]() ![]() |
I ended up getting an aftermarket silicone intake for my Subaru (that I still have yet to install...d'oh) that has all the proper ports on it, though it's designed for use with the stock, non-flipped intake manifold position.
https://www.ebay.com/itm/Silicone-Turbo-Int...;frcectupt=true That one's basically the same as the one I got, the long thin snorkel looking tube would just need a nipple fitting to allow you to plug the IAC inlet hose into it. As for stock vs aftermarket recirculation/BOVs... there's a lot of discussion about that regarding why it vents back to the intake in stock configuration. A lot of people cite that the AFRs will be messed up if it vents to atmosphere because the MAF already measured for that air. I don't know if I buy that as being THAT important since snapping the throttle closed would change the AFR regardless (plus the massive volume of compressed air would just blow back up the turbo inlet, past the MAF, and towards the airbox. Does the MAF have a way of telling what direction the air is flowing past it?) Personally, I think the MAIN reason it vents back to the intake is just because the stock Subaru airbox and intake resonators will help muffle the sound of it. |
pploco |
Chief Toilet Flusher ![]() ![]() Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains ![]() ![]() |
I ended up getting an aftermarket silicone intake for my Subaru (that I still have yet to install...d'oh) that has all the proper ports on it, though it's designed for use with the stock, non-flipped intake manifold position. https://www.ebay.com/itm/Silicone-Turbo-Int...;frcectupt=true That one's basically the same as the one I got, the long thin snorkel looking tube would just need a nipple fitting to allow you to plug the IAC inlet hose into it. As for stock vs aftermarket recirculation/BOVs... there's a lot of discussion about that regarding why it vents back to the intake in stock configuration. A lot of people cite that the AFRs will be messed up if it vents to atmosphere because the MAF already measured for that air. I don't know if I buy that as being THAT important since snapping the throttle closed would change the AFR regardless (plus the massive volume of compressed air would just blow back up the turbo inlet, past the MAF, and towards the airbox. Does the MAF have a way of telling what direction the air is flowing past it?) Personally, I think the MAIN reason it vents back to the intake is just because the stock Subaru airbox and intake resonators will help muffle the sound of it. Yep |
Lo-Fi Version | Time is now: 5th September 2025 - 08:08 AM |
