> Trouble with 1st gear, Won’t shift into first
Jackkboyes
post May 4 2019, 02:08 PM
Just bought a 72 914. Had been sitting for a long while, just got it started about a week ago. Tried to do a test drive today and it won’t shift into 1st. All the other gears are working great. Any ideas what it might be? Originally I had thought I might just need to bleed the clutch, but realized there is no grinding sounds of the gear attempting to engage. Am I going to have to do a trans rebuild or swap? Let me know if you have had similar problems or any ideas of what I can try. [quote]
Here is a pic of the car
porschetub
post May 4 2019, 02:55 PM
No clutch to bleed as its a cable operated system,make sure the cable is adjusted properly with correct pedal freeplay and all the bushes are good on the shift rod,firewall and gearbox points.
When the bushes are replaced and clutch adjusted properly you have removed two main causes so that's a good start before you go further,I would think if its not grinding this will most likely sort it for you.
Good luck.
xperu
post May 4 2019, 03:15 PM
TEXAS
QUOTE(porschetub @ May 4 2019, 03:55 PM) *
Good luck.
As stated check your cable adjustment, also check all your bushings at your shifter, at the firewall and the trans shifter. New bushings make a great improvement.
- Lo-Fi Version Time is now: 16th April 2026 - 09:41 PM
