Low oil pressure - oil pump a workable fix? |
Tdskip |
Apr 18 2019, 02:21 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yeah, yeah, I know. It's not likely the oil pump but humor me.
The red aka turbo car is showing low oil pressure. It has a front mounted oil cooler and some sort of big bore engine. Oil level is full cold and when hot. When cold my oil pressure is good, when hot it isn't. I'm under 10 PSI per 1000 RPM hot. I don't have a history on the engine. I am running 20w50, Mahle filter. I have not put a mechanical gauge on it but it is already running a retrofitted VDO oil pressure gauge. Goal is to get another summer out of driving it if I can. I supposed it wouldn't hurt to try a mechanical gauge and heavier weight oil, but is there a chance it is the oil pump rather than bearings? |
Tdskip |
May 4 2019, 03:07 PM
Yeah / seems like rebuild time.
porschetub |
May 4 2019, 03:36 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Tdskip |
May 4 2019, 04:43 PM
QUOTE(porschetub @ May 4 2019, 04:36 PM) What were the relief valves like ? and were there wear marks on the pistons and did they more freely on the case galleries ?. Reason to ask is you have good pressure when cold which would indicate the pump is ok. Hi - thanks for the follow up. I haven’t taken the engine apart so don’t know. Wondering if it is even worth messing around with the oil pressure relief spring or if I should just pull it and tear it down. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:21 PM |
