| Jackkboyes |
May 4 2019, 02:08 PM
Newbie ![]() Group: Members Posts: 4 Joined: 10-April 19 From: Salt Lake City, Utah Member No.: 23,028 Region Association: Rocky Mountains |
Just bought a 72 914. Had been sitting for a long while, just got it started about a week ago. Tried to do a test drive today and it won’t shift into 1st. All the other gears are working great. Any ideas what it might be? Originally I had thought I might just need to bleed the clutch, but realized there is no grinding sounds of the gear attempting to engage. Am I going to have to do a trans rebuild or swap? Let me know if you have had similar problems or any ideas of what I can try. [quote]
Here is a pic of the car Attached thumbnail(s) |
| Dr Evil |
May 6 2019, 01:39 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Probably a broken block in the gear. It will force the synchro band to not collapse so you cant get the slider over it. If it is not grinding, I bet this is the issue as if the band does not collapse, then the teeth cant meet the slider and no grinding will happen. Not too bad to fix. Parts arent too much. Hit me up if I can help.
Jackkboyes Trouble with 1st gear May 4 2019, 02:08 PM
porschetub No clutch to bleed as its a cable operated system,... May 4 2019, 02:55 PM
xperu
No clutch to bleed as its a cable operated system... May 4 2019, 03:15 PM
PanelBilly Search for the procedure to adjust the shifter. May 4 2019, 02:59 PM
rhodyguy Sounds like you need to purchase a Haynes manual. ... May 4 2019, 03:15 PM
worn
Sounds like you need to purchase a Haynes manual.... May 4 2019, 06:02 PM
Jackkboyes
Sounds like you need to purchase a Haynes manual... May 4 2019, 07:08 PM
914Mike
Shifts into reverse great. As well as all of the... May 5 2019, 12:25 AM
Larmo63 This is the car that you and Tanner bought, huh?
... May 4 2019, 06:21 PM
tejon007
the habit of slipping it into first just befor... May 6 2019, 03:02 PM
jcd914 Often first gear can be fixed with the trans in th... May 6 2019, 03:05 PM
tejon007 ..with or without lift...fixing thrust bearing dam... May 6 2019, 03:28 PM
Jackkboyes I’m going to try some of the quicker fixes first... May 7 2019, 03:10 PM
Jackkboyes Let me know what you all think May 7 2019, 03:12 PM
Dr Evil Well, it’s worn and cracked so can’t hurt to f... May 7 2019, 04:35 PM
Dr Evil
I was asked if I could elaborate on what I thin... May 10 2019, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 08:37 PM |
