> Trouble with 1st gear, Won’t shift into first
Jackkboyes
post May 4 2019, 02:08 PM
Just bought a 72 914. Had been sitting for a long while, just got it started about a week ago. Tried to do a test drive today and it won’t shift into 1st. All the other gears are working great. Any ideas what it might be? Originally I had thought I might just need to bleed the clutch, but realized there is no grinding sounds of the gear attempting to engage. Am I going to have to do a trans rebuild or swap? Let me know if you have had similar problems or any ideas of what I can try. [quote]
Here is a pic of the car
tejon007
post May 6 2019, 03:02 PM
[quote name='914Mike' date='May 4 2019, 11:25 PM' post='2711142']
[/quote]
the habit of slipping it into first just before the car stops rolling is much cheaper than a new first gear slider...
[/quote]
Maybe works for a temporary "fix" and you probably already know this...but, long term it will wear the TO bearing and thrust bearings ( i.e. sitting at a traffic light while holding clutch pedal down). Even more so with a heavy pressure plate.
Maybe think about putting the correct fix on your "to do" list. Best Wishes
- Lo-Fi Version Time is now: 16th April 2026 - 08:35 PM
