| HalfMoon |
May 5 2017, 05:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Sooo...it's come time to refurbish my front suspension. I don't need to do tie rods or sway bar bushings and I'm not going to work on the steering rack yet, so this'll be a "partial" rebuild.
I did some searching but really couldn't find a comprehensive guide to rebuilding the 914 front suspension. Does anyone have a link to something? I gather what I'll be doing is the torsion bar bushings, the wheel bearings and the ball joints? Are their more bushings and or bearings that I haven't included? Thanks all! |
| rhodyguy |
May 7 2019, 08:31 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Lowering your car? Bumpsteer kit. 'Shorting' the process will bite you come alignment time. Do all you can afford the first time rather than piecemeal.
HalfMoon Front suspension rebuild May 5 2017, 05:50 PM
mepstein Turbo tie rods, front strut inserts, new brake sof... May 5 2017, 06:40 PM
jmitro this has every possible item that needs attention ... May 6 2017, 06:40 AM
HalfMoon
this has every possible item that needs attention... May 6 2017, 03:51 PM
HalfMoon Sooooo, pretty much the (4) control arm bushings, ... May 6 2017, 05:18 PM
michael7810 I'm happy with the rubber bushings from Elepha... May 6 2017, 07:15 PM
HalfMoon
I'm happy with the rubber bushings from Eleph... May 6 2017, 07:36 PM
michael7810
I'm happy with the rubber bushings from Elep... May 7 2017, 07:02 AM
HalfMoon
[quote name='HalfMoon' post='2483347' date='May 6... May 7 2017, 07:37 AM
GeorgeRud Unless you're racing the car, stick with the r... May 6 2017, 07:20 PM
BillC I'm going to be replacing the control arm bush... May 8 2017, 09:16 AM
mepstein Many people have said the URO's squeak - a lot... May 8 2017, 10:20 AM
BillC
Many people have said the URO's squeak - a lo... May 8 2017, 05:30 PM
Mikey914
Many people have said the URO's squeak - a lo... May 9 2017, 08:48 PM
BillC
No, we will make the better. :D
Any idea when?... May 10 2017, 01:35 PM
Eric_Shea
Many people have said the URO's squeak - a lo... May 23 2017, 05:04 PM
raynekat Elephant Racing rubber bushings are great and wort... May 8 2017, 06:49 PM
HalfMoon Figured out my wobble. PO had failed to use a lock... May 9 2017, 01:44 PM
porschetub Yes I can imagine the URO stuff is :stromberg: ,r... May 9 2017, 10:29 PM
Mikey914 Tooling is underway right now. We have some testin... May 10 2017, 06:49 PM
HalfMoon Well replacing the ball joints didn't fix my h... May 22 2017, 04:40 PM
mepstein Check the wheel balance. May 22 2017, 06:10 PM
914_teener Yes.....I have actual experience.
Looking at your... May 23 2017, 05:42 PM
HalfMoon
Looking at you... May 24 2017, 05:02 PM
914_teener One other thing....check the steering shaft couple... May 23 2017, 05:47 PM
HalfMoon
One other thing....check the steering shaft coupl... May 24 2017, 05:02 PM
HalfMoon Well I managed to get the stock rack out today and... May 24 2017, 05:03 PM
Mendivil26 Hello,
Did you end up figuring out what the wobble... May 7 2019, 06:33 AM
HalfMoon
Hello,
Did you end up figuring out what the wobbl... May 7 2019, 08:18 AM
Larmo63 I haven't heard of anyone dissatisfied with th... May 7 2019, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 07:16 AM |
