| Jackkboyes |
May 4 2019, 02:08 PM
Newbie ![]() Group: Members Posts: 4 Joined: 10-April 19 From: Salt Lake City, Utah Member No.: 23,028 Region Association: Rocky Mountains |
Just bought a 72 914. Had been sitting for a long while, just got it started about a week ago. Tried to do a test drive today and it won’t shift into 1st. All the other gears are working great. Any ideas what it might be? Originally I had thought I might just need to bleed the clutch, but realized there is no grinding sounds of the gear attempting to engage. Am I going to have to do a trans rebuild or swap? Let me know if you have had similar problems or any ideas of what I can try. [quote]
Here is a pic of the car Attached thumbnail(s) |
| Jackkboyes |
May 7 2019, 03:10 PM
I’m going to try some of the quicker fixes first (adjusting the linkage and checking the bushings). Thanks for all the replies. I am starting with the bushings in the shifter, I’m not sure what the bushings is called, but it’s cracked (I’ll attach a picture). It’s the bushing at the end of the shifter that slides into the main linkage.
You think it could be as simple as replacing that bushing? Attached thumbnail(s) |
Jackkboyes Trouble with 1st gear May 4 2019, 02:08 PM
porschetub No clutch to bleed as its a cable operated system,... May 4 2019, 02:55 PM
xperu
No clutch to bleed as its a cable operated system... May 4 2019, 03:15 PM
PanelBilly Search for the procedure to adjust the shifter. May 4 2019, 02:59 PM
rhodyguy Sounds like you need to purchase a Haynes manual. ... May 4 2019, 03:15 PM
worn
Sounds like you need to purchase a Haynes manual.... May 4 2019, 06:02 PM
Jackkboyes
Sounds like you need to purchase a Haynes manual... May 4 2019, 07:08 PM
914Mike
Shifts into reverse great. As well as all of the... May 5 2019, 12:25 AM
Larmo63 This is the car that you and Tanner bought, huh?
... May 4 2019, 06:21 PM
Dr Evil Probably a broken block in the gear. It will force... May 6 2019, 01:39 PM
tejon007
the habit of slipping it into first just befor... May 6 2019, 03:02 PM
jcd914 Often first gear can be fixed with the trans in th... May 6 2019, 03:05 PM
tejon007 ..with or without lift...fixing thrust bearing dam... May 6 2019, 03:28 PM
Jackkboyes Let me know what you all think May 7 2019, 03:12 PM
Dr Evil Well, it’s worn and cracked so can’t hurt to f... May 7 2019, 04:35 PM
Dr Evil
I was asked if I could elaborate on what I thin... May 10 2019, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:44 PM |
