| buck toenges |
May 9 2019, 12:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 554 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None
So I am now getting ready to install the oil lines to my front oil cooler. Unfortunately the kit comes with one 22ft oil line. I would like to cut the line in two before I start threading the needle (oil lines) through the car. Does anybody know how long the lines need to be? Is one line is longer then the other?
I did notice that AA has a kit that has 2 oil lines. Does anybody know how long are those lines? (DR. hint..hint). I also need to know how much oil I need to add with the addition of the front oil cooler. I have been told 3-4 qts. I plan to add the oil as the oil gets hot. Finally does it matter if the hot oil from the engine enter the top or bottom of the oil cooler? Thaks, Buck |
| mb911 |
May 10 2019, 05:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,756 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Pmb puts all of their t stats in the front trunk, and Cairo also did in his build.. I think it's just fine.
buck toenges patrick motor sport front oil cooler question May 9 2019, 12:32 PM
mepstein If it's a setrab cooler, it's either direc... May 9 2019, 01:13 PM
buck toenges
If it's a setrab cooler, it's either dire... May 9 2019, 04:48 PM
If it's a setrab cooler, it's either dir... May 9 2019, 05:04 PM
SirAndy I am going to put the thermostat in the front trun... May 9 2019, 05:37 PM
buck toenges
I am going to put the thermostat in the front tru... May 9 2019, 06:48 PM
Larmo63 I started at the front with both, extra long and c... May 9 2019, 02:28 PM
SirAndy ...
- I have about 16 qts in my oil system
- My ... May 9 2019, 02:45 PM
mepstein I’ve read almost every 6 conversion and engine u... May 9 2019, 07:50 PM
I’ve read almost every 6 conversion and engine ... May 9 2019, 10:17 PM
I’ve read almost every 6 conversion and engine... May 10 2019, 04:22 AM
SirAndy So does the ~ 12’ of extra line when the thermos... May 10 2019, 10:03 AM
jd74914
So does the ~ 12’ of extra line when the thermo... May 10 2019, 10:50 AM
Larmo63 I ran mine in the same place in the front trunk ex... May 9 2019, 07:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:34 AM |
