| Highland |
May 13 2019, 03:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 560 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example: ![]() ![]() Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations. 2) Having much trouble taking apart the front suspension. a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way. ![]() b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out? ![]() ![]() 3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place? |
| 76-914 |
May 13 2019, 03:34 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Yes you can use a fork. Put the nut back on the bolt and whack it with a hammer. It will loosen. (IMG:style_emoticons/default/beerchug.gif)
Highland More Novice Help Please, Suspension May 13 2019, 03:20 PM
KELTY360
Yes you can use a fork. Put the nut back on the b... May 15 2019, 10:23 PM
Superhawk996 1) You can but it is only a temporary solution at... May 13 2019, 03:39 PM
jtprettyman For item #2, I'll second Superhawk - use a tie... May 14 2019, 03:45 PM
Highland Thanks.
2a) Followed your advice and went to Auto... May 14 2019, 04:19 PM
porschetub I hate the fork tool as they tend to destroy the r... May 14 2019, 04:23 PM
Highland What is the proper tool for removing the pin attac... May 14 2019, 08:25 PM
Luke M
What is the proper tool for removing the pin atta... May 15 2019, 01:39 PM
Superhawk996
What is the proper tool for removing the pin att... May 15 2019, 06:34 PM
76-914
What is the proper tool for removing the pin att... May 16 2019, 08:33 AM
914Toy
What is the proper tool for removing the pin atta... May 15 2019, 02:07 PM
mepstein I bought a pair of 911 struts super cheap because ... May 15 2019, 06:57 PM
Superhawk996
I bought a pair of 911 struts super cheap because... May 15 2019, 07:33 PM
I bought a pair of 911 struts super cheap becaus... May 15 2019, 07:38 PM
malcolm2 Tangerine Racing has CV joints. If 3 of yours are... May 15 2019, 07:32 PM
Highland More heat and I got the ball joint pins out. Kind ... May 16 2019, 07:10 PM
Superhawk996 Nice job. You’re on your way!
:beer2: May 16 2019, 07:20 PM
mepstein Usually, you only need to replace torsion bars if ... May 16 2019, 07:35 PM
bbrock
Tangerine Racing has CV joints. If 3 of yours ar... May 16 2019, 07:47 PM
rhodyguy Spray down the thread end. Smack the othe side, wh... May 16 2019, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 08:59 PM |
