jb57tub |
jb57tub ![]() Group: Members Posts: 23 Joined: 9-January 19 From: Corpus Christi, Tx Member No.: 22,790 Region Association: Southwest Region ![]() |
What machine work needs to be done on an early 1.7 case to convert it to a stock 2 ltr motor? thanks for any help, Jon
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
I believe the thinking behind using the 1.7L case is that the 1.7 case is less stressed and therefore less likely to be damaged or need a lot of machining to be usable.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I believe the thinking behind using the 1.7L case is that the 1.7 case is less stressed and therefore less likely to be damaged or need a lot of machining to be usable. Jake Raby has also mentioned they had better metallurgy and he uses them to build his big hp engines. |
Lo-Fi Version | Time is now: 6th July 2025 - 03:23 PM |
