| Morph914 |
May 13 2019, 07:48 PM
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States
I purchased these along with my a arm bushings. I am about to install the a arm bushings and have a clear understanding of how to install those, but not the trailing arm bushings. I have watched a video on the trailing arm bushings install, but the type of bushing he was using is unknown unless I missed something. Do 914 Rubber trailing arm bushings get installed with grease? Are these rubber or teflon?
Thanks for any input, John |
| bbrock |
May 14 2019, 05:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Hey John,
I used electrical tape to wrap around the tools to take out the slop. IIRC, each end of the A-arm was a little different. Sorry you had bad luck on the first try. I didn't used a temp gun on the boiling water either but because I'm at altitude, I boiled them for a good 20-30 minutes. |
Morph914 Trailing arm bushings May 13 2019, 07:48 PM
bbrock Those are harder rubber than the A-arm bushings an... May 13 2019, 08:10 PM
Those are harder rubber than the A-arm bushings a... May 13 2019, 08:37 PM
Morph914 Thank you.
Well, I thought I had everything I nee... May 14 2019, 05:11 PM
Morph914 Thanks, I’ll try boiling for a longer period of ... May 14 2019, 08:07 PM
mepstein Boiling water only gets to 212 no matter how long ... May 14 2019, 08:42 PM
bbrock
Boiling water only gets to 212 no matter how long... May 14 2019, 10:48 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... May 15 2019, 08:43 AM
bigkensteele I used a Harbor Freight 12 ton press to install my... May 14 2019, 09:09 PM
Dr916Gt Just did these last week converted my 914 to a six... May 15 2019, 09:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 09:03 PM |
