| Mark Henry |
Apr 21 2019, 09:03 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s)
| Mark Henry |
Apr 21 2019, 12:42 PM
I likely could make each one around $10 cheaper using loose wire and the braided plastic covering.
Not near as nice as the UL grade cable I'm using. The braided covering is also too expensive locally, to get the price brake I'd have to order it from china, ETA 8 weeks. Attached image(s)
| ctc911ctc |
May 15 2019, 11:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,395 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Ready to ship yet?
[ quote name='Mark Henry' date='Apr 21 2019, 12:42 PM' post='2707440'] I likely could make each one around $10 cheaper using loose wire and the braided plastic covering. Not near as nice as the UL grade cable I'm using. The braided covering is also too expensive locally, to get the price brake I'd have to order it from china, ETA 8 weeks. [/quote] |
Mark Henry Gauging interest...pun intended Apr 21 2019, 09:03 AM
Mark Henry The meter works with any fuel, gas, diesel, alcoho... Apr 21 2019, 09:08 AM
mobymutt I have interest, although I've pretty much blo... Apr 21 2019, 09:21 AM
Mark Henry As I said these come as a kit, I have to solder in... Apr 21 2019, 09:23 AM
mepstein I'll take one. Tell me when you want money. Th... Apr 21 2019, 09:30 AM
Mark Henry
I'll take one. Tell me when you want money. T... Apr 21 2019, 09:39 AM
Mark Henry This shows the solder job on the daughter board, I... Apr 21 2019, 09:45 AM
Mark Henry The 4.9 LSU connector, 2nd pic black doesn't s... Apr 21 2019, 09:56 AM
Mark Henry This is the power and output leads, fuse and holde... Apr 21 2019, 10:06 AM
jd74914 How much? Is that a 14point7 SLC board? Apr 21 2019, 10:26 AM
Mark Henry
Yes it... Apr 21 2019, 12:10 PM
jd74914
Yes it's a 14point7 (.com) I thought I said t... Apr 22 2019, 10:27 AM
mb911 Mark,
I think I would be in.. I need something an... Apr 21 2019, 01:41 PM
Mark Henry
Mark,
I think I would be in.. I need something a... Apr 21 2019, 02:20 PM
mb911 Mark ,
1/4" should be perfect. I just did t... Apr 21 2019, 07:28 PM
Mark Henry
Mark ,
1/4" should be perfect. I just did ... Apr 22 2019, 05:17 AM
tmessenger I bought one of these for my car a couple of month... Apr 21 2019, 08:03 PM
mb911 Mark,
I had always read 10 to 2 o clock? Apr 22 2019, 05:35 AM
Mark Henry
Mark,
10 or ... Apr 22 2019, 11:09 AM
914forme Dual setup would be my choice if your counting Mar... Apr 22 2019, 07:53 AM
mepstein :) Apr 22 2019, 11:17 AM
mb911 I was just looking at innovates website after I wr... Apr 22 2019, 11:32 AM
Mark Henry Maybe I'm wrong or misinformed, wouldn't b... Apr 22 2019, 12:41 PM
mb911
Maybe I'm wrong or misinformed, wouldn't ... Apr 22 2019, 02:52 PM
Gary Mark, I'm in for a setup too, probably a two-h... Apr 22 2019, 05:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 03:50 AM |
