| Highland |
May 13 2019, 03:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 560 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example: ![]() ![]() Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations. 2) Having much trouble taking apart the front suspension. a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way. ![]() b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out? ![]() ![]() 3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place? |
| Highland |
May 14 2019, 08:25 PM
What is the proper tool for removing the pin attaching the strut to the A-arm ball joint?
Picture would be great (IMG:style_emoticons/default/smile.gif) Do most just replace the ball joint? My boot is still solid, but is that the only criteria? |
| Luke M |
May 15 2019, 01:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,623 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
What is the proper tool for removing the pin attaching the strut to the A-arm ball joint? Picture would be great (IMG:style_emoticons/default/smile.gif) Do most just replace the ball joint? My boot is still solid, but is that the only criteria? Put the nut back on the threads, grab the biggest hammer you have and give it a good smack. Those pins are suppose to be a one time use only. You can buy new ones at PP, PMB or the dealer. |
| 76-914 |
May 16 2019, 08:33 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
What is the proper tool for removing the pin attaching the strut to the A-arm ball joint? Picture would be great (IMG:style_emoticons/default/smile.gif) Do most just replace the ball joint? My boot is still solid, but is that the only criteria? Put the nut back on the threads, grab the biggest hammer you have and give it a good smack. Those pins are suppose to be a one time use only. You can buy new ones at PP, PMB or the dealer. Back to post #2 (IMG:style_emoticons/default/shades.gif) |
Highland More Novice Help Please, Suspension May 13 2019, 03:20 PM
76-914 Yes you can use a fork. Put the nut back on the bo... May 13 2019, 03:34 PM
KELTY360
Yes you can use a fork. Put the nut back on the b... May 15 2019, 10:23 PM
Superhawk996 1) You can but it is only a temporary solution at... May 13 2019, 03:39 PM
jtprettyman For item #2, I'll second Superhawk - use a tie... May 14 2019, 03:45 PM
Highland Thanks.
2a) Followed your advice and went to Auto... May 14 2019, 04:19 PM
porschetub I hate the fork tool as they tend to destroy the r... May 14 2019, 04:23 PM
Superhawk996
What is the proper tool for removing the pin att... May 15 2019, 06:34 PM
914Toy
What is the proper tool for removing the pin atta... May 15 2019, 02:07 PM
mepstein I bought a pair of 911 struts super cheap because ... May 15 2019, 06:57 PM
Superhawk996
I bought a pair of 911 struts super cheap because... May 15 2019, 07:33 PM
I bought a pair of 911 struts super cheap becaus... May 15 2019, 07:38 PM
malcolm2 Tangerine Racing has CV joints. If 3 of yours are... May 15 2019, 07:32 PM
Highland More heat and I got the ball joint pins out. Kind ... May 16 2019, 07:10 PM
Superhawk996 Nice job. You’re on your way!
:beer2: May 16 2019, 07:20 PM
mepstein Usually, you only need to replace torsion bars if ... May 16 2019, 07:35 PM
bbrock
Tangerine Racing has CV joints. If 3 of yours ar... May 16 2019, 07:47 PM
rhodyguy Spray down the thread end. Smack the othe side, wh... May 16 2019, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 08:59 PM |
