> More Novice Help Please, Suspension, CV Joint and Front Suspension Disassembly
Highland
post May 13 2019, 03:20 PM
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example:
Attached ImageAttached Image
Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations.
2) Having much trouble taking apart the front suspension.
a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way.
b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out?
3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place?
Superhawk996
post May 16 2019, 07:20 PM
Nice job. You’re on your way!
Highland   More Novice Help Please, Suspension   May 13 2019, 03:20 PM
76-914   Yes you can use a fork. Put the nut back on the bo...   May 13 2019, 03:34 PM
KELTY360   Yes you can use a fork. Put the nut back on the b...   May 15 2019, 10:23 PM
Superhawk996   1) You can but it is only a temporary solution at...   May 13 2019, 03:39 PM
jtprettyman   For item #2, I'll second Superhawk - use a tie...   May 14 2019, 03:45 PM
Highland   Thanks. 2a) Followed your advice and went to Auto...   May 14 2019, 04:19 PM
porschetub   I hate the fork tool as they tend to destroy the r...   May 14 2019, 04:23 PM
Highland   What is the proper tool for removing the pin attac...   May 14 2019, 08:25 PM
Luke M   What is the proper tool for removing the pin atta...   May 15 2019, 01:39 PM
Superhawk996   What is the proper tool for removing the pin att...   May 15 2019, 06:34 PM
76-914   What is the proper tool for removing the pin att...   May 16 2019, 08:33 AM
914Toy   What is the proper tool for removing the pin atta...   May 15 2019, 02:07 PM
mepstein   I bought a pair of 911 struts super cheap because ...   May 15 2019, 06:57 PM
Superhawk996   I bought a pair of 911 struts super cheap because...   May 15 2019, 07:33 PM
mepstein   I bought a pair of 911 struts super cheap becaus...   May 15 2019, 07:38 PM
malcolm2   Tangerine Racing has CV joints. If 3 of yours are...   May 15 2019, 07:32 PM
Highland   More heat and I got the ball joint pins out. Kind ...   May 16 2019, 07:10 PM
Superhawk996   Nice job. You’re on your way! :beer2:   May 16 2019, 07:20 PM
mepstein   Usually, you only need to replace torsion bars if ...   May 16 2019, 07:35 PM
bbrock   Tangerine Racing has CV joints. If 3 of yours ar...   May 16 2019, 07:47 PM
rhodyguy   Spray down the thread end. Smack the othe side, wh...   May 16 2019, 08:02 PM
- Lo-Fi Version Time is now: 15th November 2026 - 08:59 PM
