> Fuel Pump Wiring Experts, I need help
wndsnd
post May 17 2019, 07:53 PM
You wanted a horse, but got a goat. Nobody wants a goat....
My fuel pump is in the front.
It is fed by the original wiring at the rear suspension point
If I power the fuel pump from an auxiliary 12 volt source fed from the rear, the pump runs. That eliminates the wiring from rear to front, and the pump.
If I put a meter on the pump wiring at suspension point I get a reading of hundreds of volts. How do I get Hundreds of volts from a 12 volt circuit. I am guessing a short would cause amps, not volts.
I have been changing relays, and the board. I did what Dave Darling mentions and checked out the #30 at both board relays. I had constant 12 V there I changed the fuses.
Car was run hard in the rain for a couple of days. I suspect water got into something but where? Relay board was covered. Everything else seems ok. Maybe it is not water. What do you guys think? It has to be somewhere between the board and the wiring at suspension point. Is there another connector between the suspension point and the board? Lots of questions..... Sorry.
Thanks
Spoke
post May 17 2019, 08:10 PM
Jerry
I assume the car won't start because the fuel pump isn't running, correct?
What type of connection do you have at the original location? Cut and spliced wire? Crimped?
What fuel system do you have? Carbs? FI? If carbs do you have a jumper on pin 3 of the FI power connector?
Follow the fuel pump power path starting at the 25A fuse. Measure voltage on both sides of the fuse.
From there check the voltage at pin 87 of the fuel pump relay K75. You can do this by pulling the relay and inserting a very small wire in the pin 87 socket hole and replacing the relay.
You may want to check the ground wire at the original location. When you measure hundreds of volts, measure each wire to chassis. For the ground wire, you should have zero volts and 12V on the other wire.
wndsnd
post May 17 2019, 08:15 PM
QUOTE(Spoke @ May 17 2019, 10:10 PM) *
I assume the car won't start because the fuel pump isn't running, correct? I used a jump pack and fed the pump directly and the pump and engine ran fine.
What type of connection do you have at the original location? Cut and spliced wire? Crimped? I use crimp connectors with heat shrink I crimp twice.
What fuel system do you have? Carbs? FI? If carbs do you have a jumper on pin 3 of the FI power connector? Running Webers yes have the jumper, no changes made.
Follow the fuel pump power path starting at the 25A fuse. Measure voltage on both sides of the fuse. Have not done that.
From there check the voltage at pin 87 of the fuel pump relay K75. You can do this by pulling the relay and inserting a very small wire in the pin 87 socket hole and replacing the relay. Will do this tomorrow.
You may want to check the ground wire at the original location. When you measure hundreds of volts, measure each wire to chassis. For the ground wire, you should have zero volts and 12V on the other wire. Good Idea.
wndsnd
post May 17 2019, 08:23 PM
QUOTE(wndsnd @ May 17 2019, 10:15 PM) *
wndsnd
post May 17 2019, 08:24 PM
QUOTE(wndsnd @ May 17 2019, 10:23 PM) *
wndsnd   Fuel Pump Wiring Experts   May 17 2019, 07:53 PM
Dave_Darling   Hundreds of volts should only be possible if you...   May 17 2019, 07:56 PM
wndsnd   Dave, I see that pin 13 off the board feeds the pu...   May 17 2019, 08:04 PM
wndsnd   There is no coil but high voltage twin plug coil ...   May 17 2019, 08:09 PM
Spoke   I assume the car won't start because the fuel ...   May 17 2019, 08:10 PM
wndsnd   I assume the car won't start because the fuel...   May 17 2019, 08:15 PM
wndsnd   [quote name='Spoke' post='2714697' date='May 17 2...   May 17 2019, 08:23 PM
wndsnd   [quote name='wndsnd' post='2714698' date='May 17 ...   May 17 2019, 08:24 PM
worn   Hi Spoke, Is it reasonable to assume some sort of ...   May 17 2019, 08:29 PM
Spoke   Hi Spoke, Is it reasonable to assume some sort of...   May 17 2019, 08:37 PM
wndsnd   Hi Spoke, Is it reasonable to assume some sort o...   May 17 2019, 08:42 PM
wndsnd   Hi Spoke, Is it reasonable to assume some sort of...   May 17 2019, 08:38 PM
Spoke   Hi Spoke, Is it reasonable to assume some sort o...   May 18 2019, 05:54 AM
wndsnd   [quote name='worn' post='2714706' date='May 17 2...   May 18 2019, 09:43 AM
wndsnd   [quote name='Spoke' post='2714781' date='May 18 2...   May 18 2019, 09:44 AM
wndsnd   I will do the suggested tests tomorrow. Thank you...   May 17 2019, 08:46 PM
mtndawg   How many volts do you have on the positive (15) si...   May 17 2019, 11:31 PM
wndsnd   How many volts do you have on the positive (15) s...   May 18 2019, 09:43 AM
Specracer   LONG SHOT question, is the battery fresh in your m...   May 18 2019, 03:42 AM
wndsrfr   LONG SHOT question, is the battery fresh in your ...   May 18 2019, 05:31 AM
wndsnd   LONG SHOT question, is the battery fresh in your...   May 18 2019, 09:46 AM
Superhawk996   If your meter is operating correctly and you are g...   May 18 2019, 10:29 AM
wndsnd   Fixed! I pulled the relay board and WD40...   May 18 2019, 10:50 AM
- Lo-Fi Version Time is now: 19th October 2026 - 04:57 AM
