> 914 1.7 to a 2.0 (VW), 914 1.7 to a 2.0 (VW)
PTP
post May 19 2019, 08:01 AM
Hello All!
I'm new to this forum as I have recently bought a 1970, 1.7L, 914. The engine needs quite a bit of work and I'm considering to replace it by a 2.0, from a vintage VW.
Would you say that such engine would work/fit in the 914? Are they visually alike? Would there be the need of a great adaption in the car?
Thank you in advance!
Bleyseng
post May 19 2019, 08:09 AM
Aircooled Baby!
What vintage VW? A type 1? (Beetle) or a type 2 (Transporter)? I'd say no to a type 1 engine as it has the upright fan setup which does work well and there isn't a way to use the 914 flywheel/clutch set up on a type 1 so the starter won't engage. A type 2 engine will work and you just swap all the 914 tin over to the engine, all the FI stuff and the 914 flywheel will fit too! All 70hp will be a disappointment in the 914 but it will run.
PTP
post May 19 2019, 11:41 AM
QUOTE(Bleyseng @ May 19 2019, 03:09 PM) *
Thank you very much for your reply. I need to check exactly where the engine is coming from, but I think it's a T4...
Superhawk996
post May 19 2019, 12:21 PM
QUOTE(PTP @ May 19 2019, 01:41 PM) *
Ha!
I just noticed you are from Portugal. Sweet! You guys have some corners. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/pray.gif)
Guys like me . . . I'm trapped in the midwest with nothing but straight roads. (IMG:style_emoticons/default/barf.gif)
- Lo-Fi Version Time is now: 9th December 2025 - 07:00 PM
