Shifter in 4th position for engine removal? |
MikeM |
May 21 2019, 09:14 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...did I read somewhere that leaving the shifter in 4th before removing the rear shift rod is advantageous for some reason? Does that maintain your shifter adjustment or something?
Searched unsuccessfully... Thanks |
VaccaRabite |
May 21 2019, 09:34 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As to adjustment of the shifter. In theory the cone screws maintain the same geometry of the shift rod on re-assembly. Keep in mind that the cone screws are single use items, and need to be replaced once they are removed.
In practice, it is always possible that some fine tuning to the shifter may need to happen after engine re-installation. Usually you are good, but not always. Especially if you have replaced a worn item (like a worn out cone screw or a roached bushing). Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:45 AM |
