Fuel pump not running |
Rand |
May 19 2019, 05:29 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
75, 2.0, djet. Won't fire. Spark is good. A little starting fluid in the intake and it fires. Clearly a fuel problem. I'm not hearing the fuel pump. Shouldn't I hear it for a few seconds when first turning ignition on? I checked the fuse (#25 on the relay board) and it's good. I'll put a multimeter on the pump terminals to check for power next, but thought I'd throw this out there to the collective for any other input until I can get back to it. Grounds are also on the list. Or put power directly to the pump and see if it runs.
(IMG:style_emoticons/default/beerchug.gif) |
dralf |
May 21 2019, 02:11 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
I may be having similar issues.... will try jumping out my relay once I figure out which is the pin mentioned.
lierofox |
May 21 2019, 04:43 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
I may be having similar issues.... will try jumping out my relay once I figure out which is the pin mentioned. https://i.imgur.com/Nau5VmA.jpg Bottom left corner of this image. The left yellow circled terminal is the one Spoke is referring to. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:27 AM |
