| buck toenges |
May 15 2019, 05:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None
I have decided to place my thermostat in the front trunk. I think it is easier for me to do that. I am routing the oil lines back to the engine compartment. Here are a few pics of my current set up on my 3.2. I could use some help plumbing the new oil lines back to the engine and oil tank. Can you tell me how to connect the new oil lines to the current oil lines please.
Here is the line from the bottom of engine to the oil tank. Here is the oil line from the tank. I am not sure where it goes. Here is another picture of this line that has the oil removal plug. I didn't picture the other oil line on top of the oil tank that I thinks goes to the cooler on the engine. So I am looking if I can use any of these lines in conjunction with the two oil lines coming back to the engine compartment on the drivers side. Thanks, Buck |
| sixnotfour |
May 22 2019, 02:55 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,403 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
the one with the drain T is the direct supply to the engine...stays as is....
braided line running along fire wall is the return line to oil tank.. after it goes thru motor....hot that line now needs too be routed to one of the hard lines... The other hard line need a hose to go back to the tank... Question...what is in the heat wrap by the oil line,,by the fire wall ? fuel lines ? |
| buck toenges |
May 23 2019, 11:25 AM
the one with the drain T is the direct supply to the engine...stays as is.... braided line running along fire wall is the return line to oil tank.. after it goes thru motor....hot that line now needs too be routed to one of the hard lines... The other hard line need a hose to go back to the tank... Question...what is in the heat wrap by the oil line,,by the fire wall ? fuel lines ? It is actually heat wrap over the e-brake. Can't tell you why this was done. Buck |
buck toenges running oil cooler lines to the engine now May 15 2019, 05:24 PM
Mike D. What line are you using to go to the front? Less f... May 15 2019, 05:30 PM
mepstein Its a bit hard to see the big picture from your pi... May 15 2019, 05:56 PM
Krieger Your oil removal plug is really close to the groun... May 15 2019, 06:32 PM
Your oil removal plug is really close to the grou... May 15 2019, 06:41 PM
mb911 Are you asking what line connects to the oil coole... May 15 2019, 07:03 PM
rgalla9146
the one with the drain T is the direct supply to ... May 22 2019, 06:16 PM
mb911
the one with the drain T is the direct supply to... May 22 2019, 07:47 PM
mb911 This is a decent picture but pbase has more pictur... May 22 2019, 03:20 PM
worn
This is a decent picture but pbase has more pictu... May 22 2019, 09:56 PM
This is a decent picture but pbase has more pict... May 23 2019, 05:27 AM
sixnotfour
Is why I worded my reply the way I did....
Yes R... May 23 2019, 09:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 01:57 AM |
