Fuel Percolating in Carb.... |
MikeM |
May 23 2019, 06:28 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...my friend and I are both having the same problem with fuel boiling or percolating in the carbs after shut down. It drips out of the carbs and onto the intake manifold. It's not much but it's dangerous and smells terrible. We both have Weber 44's and we are using the thick spacers between the heads and intakes. I have ordered the thick spacers for under the carbs also. Is there anything else to consider with this problem?
It wasn't even hot today and oil temps only about 200 degrees!! Any and all suggestions appreciated!! Mike |
brant |
May 24 2019, 10:26 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
adding a return circuit can be a big help with this
I hate seeing all of the advice on the internet saying that a return line is unnecessary. the fuel in the bowl still gets hot but at least the fuel sitting above the motor inside of a fuel line isn't absorbing radiant heat... at least it is moving around and relatively cool when it enters the bowl. b |
Lo-Fi Version | Time is now: 8th June 2024 - 11:17 AM |
