Rear sway bar yes or no?, 22mm hollow RSR Style Tarett sway bar front, rear sway bar needed or not? |
CG-914 |
May 25 2019, 08:16 AM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi 914 suspension wizards,
I do club racing with the POC in CA on the tight handling courses so far (IMG:style_emoticons/default/piratenanner.gif) . I'm about to install a front Tarett 22mm hollow RSR style sway bar. Rear sway bar yes or no? I do still drive the car on the street as well.... The car has Toyo R888, 140lbs springs so far, but it eventually is going to a 6 with 22mm torsion bars in the front and adjustable 300lbs springs in the rear and of course a 5 lug conversion. Thanks |
brant |
May 26 2019, 08:22 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I run a rear bar
My set up Is race only 21 hollow front torsions 275 rear springs A 27mm (or 28?) smart bar in front A 16mm rear bar with adjustable drop links |
Lo-Fi Version | Time is now: 6th June 2024 - 12:11 PM |
