> 19mm Master Cylinder
marks914
post Nov 29 2004, 05:59 PM
OK
I have read many articles about the 19mm master cyl. upgrade. Just wanted some feedback. I know that the 19mm will have a pedal that is harder to push. I am installing a five lug conversion right now. Up front: 82 SC rotors and calipers (non turbo). In the rear: stock 914-4 rear calipers and rotors. Could I get away with a 17mm? I would like a easier pedal. Has anyone used the 17mm with a similar setup?
I am also getting cold lying on the floor of my garage. Here in Detroit its getting cold!
Thanks
Mark
Oh yeah, found out that my15x7 polished fuchs( 23.3mm offset) stick ouy as far as my rear fender lip. Guess I will use my phone dials.
SpecialK
post Nov 29 2004, 08:52 PM
aircraft surgeon
I've got the BMW 320i calipers up front, 19mm MC, with stock rears and a "T" in place of the proportioning valve. Can't give an opinion on how well this set up works because everything is still boxed up and sitting on a shelf in the garage.
A PP article might be helpful in answering your question:
http://www.pelicanparts.com/techarticles/9...MW_calipers.htm
If not, at least you're bumped up the page (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/icon_bump.gif)
Kevin
marks914   19mm Master Cylinder   Nov 29 2004, 05:59 PM
SpecialK   I've got the BMW 320i calipers up front, 19mm ...   Nov 29 2004, 08:52 PM
JOHNMAN   I'll add my $0.02 We had a 19 mm master ...   Nov 30 2004, 12:17 AM
- Lo-Fi Version Time is now: 6th July 2025 - 08:44 PM
