Sticky pressure relief valve?, Erratic oil pressure issues with new T4 motor |
RoadGlue |
May 27 2019, 07:22 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hey everyone, hope you're all doing well.
My newly built four banger's oil pressure is all over the board and I'd really appreciate any advice you might have. When the pressure is behaving normally, I'm seeing a pretty normal fluctuation from 10 PSI at idle to 40-something at cruise. However it seems that depending on direction I'm turning (maybe!?) the pressure can jet up to 65+ PSI which of course is alarming. Worried I'm going to blow out seals. It doesn't always jump up though. It's rather inconsistent. At idle I've had it stick at around 60 lbs as well. Giving the throttle a jab seems to free it up and it'll drop back down to where it's supposed to be. I think it's a stuck pressure relief valve. If it were stuck in a high pressure state, would cornering have some effect on the pressure spikes? I'm using Penn 20-50 and everything I listed was at normal operating temps (130-180 F). Thanks!! |
ChrisFoley |
May 28 2019, 06:35 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I say its unlikely because the pressure relief valve doesn't work the way you imagine it does. But it is hard to imagine how going around a corner could affect the relief circuit.
Another point - oil pressure above 65 psi will not blow seals. My modified pressure relief valve raises the max pressure to 75 psi. In fact, the first thing to fail if oil pressure actually gets too high will most likely be a galley plug. Cold oil pressure can easily exceed relief valve design pressure simply because the return passage is too small to bleed off all the excess oil when it's thick. |
RoadGlue |
May 29 2019, 12:59 PM
I say its unlikely because the pressure relief valve doesn't work the way you imagine it does. But it is hard to imagine how going around a corner could affect the relief circuit. Another point - oil pressure above 65 psi will not blow seals. My modified pressure relief valve raises the max pressure to 75 psi. In fact, the first thing to fail if oil pressure actually gets too high will most likely be a galley plug. Cold oil pressure can easily exceed relief valve design pressure simply because the return passage is too small to bleed off all the excess oil when it's thick. Thanks for this! The more data the better. |
Lo-Fi Version | Time is now: 15th June 2024 - 06:46 PM |
