> Engine failure on track day, need some help, T4 GB 2.0 head failure
CheeRS
post May 10 2019, 01:08 PM
Region Association: France
Hi, here is my presentation post :
http://www.914world.com/bbs2/index.php?showtopic=337989
two weeks ago I was in Monthlery near Paris France, for a wagenfest with my 914.
Get some troubles with the engine, a hammer noise and the engine stopped smoothly like out of gas.
here is what I found :
https://drive.google.com/open?id=1gzsWwNBOh...86Kbof2P4BCHHrm
some pics
Bleyseng
post Jun 1 2019, 07:54 AM
Aircooled Baby!
http://www.dakotadigital.com/index.cfm/pag...prod/prd347.htm
This gives you instant readings of your head temps as you don't want to go over 425 degrees.
I recommend getting your heads combustion chambers thermal coated to stop the heat sinking and protect the from damage due to heat.
CheeRS   Engine failure on track day, need some help   May 10 2019, 01:08 PM
CheeRS   my own workshop, this is a Aircooled specialized s...   May 10 2019, 01:20 PM
CheeRS   cylinder 3 admission valve stand in open position   May 10 2019, 01:21 PM
CheeRS   Opening the engine and disassembling the djetronic...   May 10 2019, 01:29 PM
914_teener   Opening the engine and disassembling the djetroni...   May 10 2019, 01:33 PM
CheeRS   Opening the engine and disassembling the djetron...   May 10 2019, 02:07 PM
914_teener   classic dropped valve seat. Pull the heads and re...   May 10 2019, 01:30 PM
914_teener   Follow the ecu harness back from the ECU...you sho...   May 10 2019, 02:30 PM
CheeRS   Thanks, to be sure I will track the wire and the n...   May 10 2019, 02:55 PM
GregAmy   I'd be more worried about the dropped valve se...   May 10 2019, 06:00 PM
CheeRS   I'd be more worried about the dropped valve s...   May 11 2019, 12:42 AM
bandjoey   For a guy with that shop, I don't think he wor...   May 10 2019, 06:11 PM
Chi-town   Have the head checked for cracks before you waste ...   May 10 2019, 07:02 PM
Dave_Darling   After you look at the heads, consider the LN serie...   May 10 2019, 08:46 PM
Superhawk996   After you look at the heads, consider the LN seri...   May 11 2019, 08:22 PM
CheeRS   more   May 11 2019, 12:43 AM
Bleyseng   If I were you I'd order a set of new castings ...   May 11 2019, 08:43 AM
CheeRS   If I were you I'd order a set of new castings...   May 11 2019, 06:36 PM
sithot   If I were you I'd order a set of new casting...   May 12 2019, 02:24 PM
rhodyguy   Do you intend just to do the one head?   May 11 2019, 08:56 AM
CheeRS   Do you intend just to do the one head? I will a...   May 11 2019, 06:38 PM
Bleyseng   Buy a set of these with the coating to keep the he...   May 11 2019, 09:57 AM
CheeRS   Buy a set of these with the coating to keep the h...   May 11 2019, 06:38 PM
Bleyseng   Buy a set of these with the coating to keep the h...   Jun 1 2019, 10:38 AM
BeatNavy   https://newsite.hamheads.com/home/ Contact Len Ho...   May 11 2019, 06:47 PM
Jetsetsurfshop   :D Good money spent.   May 11 2019, 07:36 PM
Dave_Darling   Sorry, I meant LE series heads. But they look to ...   May 11 2019, 10:15 PM
porschetub   I would be rather worried about rebuilding those h...   May 11 2019, 11:58 PM
CheeRS   I had a look on amc spain, 914 heads are not avail...   May 12 2019, 02:21 AM
Superhawk996   About head seals, on a french forum, I get the d...   May 12 2019, 08:06 AM
r_towle   no head seal (gasket) needed. You can lap the cyli...   May 12 2019, 08:27 AM
CheeRS   no head seal (gasket) needed. You can lap the cyl...   May 12 2019, 04:51 PM
porschetub   no head seal (gasket) needed. You can lap the cy...   May 12 2019, 06:31 PM
Mark Henry   You can get new bare 914 2.0 cores from AA perform...   May 12 2019, 12:13 PM
Bleyseng   You can get new bare 914 2.0 cores from AA perfor...   May 12 2019, 03:51 PM
CheeRS   tomorrow I dismount the second cylinder head and I...   May 13 2019, 04:19 PM
CheeRS   the actual pistons are AA 93,95   May 14 2019, 05:34 AM
CheeRS   Bonsoir tout le monde, with your help, thinks are ...   May 16 2019, 01:44 PM
veltror   Since you are in Europe, just across the water tal...   May 16 2019, 04:38 PM
CheeRS   Hello, this week, heads will be shipped to the spe...   May 18 2019, 02:37 PM
CheeRS   Was surprised to found this modification on my eng...   May 18 2019, 02:39 PM
CheeRS   this screw is not original. Why make this ? Perhap...   May 18 2019, 02:43 PM
billh1963   I've seen a picture like that before... <_...   May 18 2019, 03:14 PM
CheeRS   Hello, Heads, pistons and cylinders are at the mac...   May 28 2019, 09:53 AM
CheeRS   more   May 28 2019, 09:54 AM
CheeRS   Is the block dead ?   May 28 2019, 09:55 AM
CheeRS   last one   May 28 2019, 09:56 AM
CheeRS   with nail we feel an angle so the block has moved   May 28 2019, 09:57 AM
Dave_Darling   We would call those "cracks", not ...   May 28 2019, 11:40 AM
sixnotfour   out side of case,,get a die kit,,,casting flaws ??   May 28 2019, 12:09 PM
ChrisFoley   I see casting lines, not cracks.   May 28 2019, 06:37 PM
Jetsetsurfshop   I see casting lines, not cracks. Same. Casting...   May 28 2019, 07:40 PM
Dave_Darling   Well, if Chris says they're not cracks, believ...   May 28 2019, 08:53 PM
sixnotfour   I Pointed to a true solution ...not an opinion..   May 28 2019, 08:54 PM
Bleyseng   I Pointed to a true solution ...not an opinion.. ...   May 28 2019, 09:09 PM
McMark   :agree: Casting marks. Nothing more.   May 29 2019, 01:12 PM
CheeRS   :DRUNK: Thanks and CheeRS. now two more question...   May 31 2019, 02:30 PM
Montreal914   I think someone on The Samba is rebuilding them. N...   May 31 2019, 02:49 PM
CheeRS   You should consider a cylinder head temperature ga...   Jun 1 2019, 12:20 AM
Bleyseng   http://www.dakotadigital.com/index.cfm/pag...prod/...   Jun 1 2019, 07:54 AM
Montreal914   I've been using this one: http://thesensorcon...   Jun 1 2019, 10:30 AM
CheeRS   hello, heads came back from the shop, new seat, he...   Jul 5 2019, 03:19 PM
CheeRS   in the moment I started to go up but without doing...   Jul 5 2019, 03:21 PM
CheeRS   Lastly, I wanted to install 911 elephant feet but ...   Jul 5 2019, 03:24 PM
Bleyseng   You must grind off some of the rocker arm (while n...   Jul 5 2019, 05:40 PM
Jake Raby   Wow, a dropped intake seat.. I thought all those t...   Jul 5 2019, 05:53 PM
CheeRS   Thanks, and what about cylinders 1 & 2 and 3 ...   Jul 5 2019, 11:39 PM
Bleyseng   You can take a cylinder and using valve lapping co...   Jul 6 2019, 09:42 AM
CheeRS   by cleaning very carefully all the surfaces and ch...   Jul 8 2019, 02:56 PM
Bleyseng   In inches thats .0314 which is pretty tight deck a...   Jul 8 2019, 03:23 PM
CheeRS   I saw some pics showing testing the gap with a cla...   Jul 8 2019, 03:36 PM
Bleyseng   Yes but we are worried about the piston hittinh th...   Jul 8 2019, 04:55 PM
CheeRS   logic, thanks, will add shin to get 0.04   Jul 8 2019, 11:10 PM
CheeRS   Engine returned today in the car. A lot of parts c...   Sep 9 2019, 02:06 PM
CheeRS   you can see it on this photo   Sep 9 2019, 02:07 PM
rhodyguy   That oil temp wire should be mounted on a stud beh...   Sep 10 2019, 07:50 AM
sportlicherFahrer   The oil temp wire plugs in to the main harness nea...   Sep 10 2019, 09:14 AM
- Lo-Fi Version Time is now: 8th December 2025 - 10:33 PM
