| Literati914 |
Jun 11 2019, 10:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,380 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm gonna order the following items to convert over to an electric windshield washer system, but have some questions about the washer stalk on the column. With the stock set up, how many speeds are there for the wiper action? Is it JUST low and hi only, or is there a middle speed too? (too many years since my last 914 to remember, and it hardly ever rains, so..) Also, is there an intermittent action (I doubt), and is there a way to add it? Same question with the replacement stalk I'm considering (see link)?
https://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G and https://www.ebay.com/itm/BRAND-NEW-WINDSHIE...scAAOSw5ZBWPTnf . |
| Valy |
Jun 11 2019, 06:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
That switch is described as 6 pin connector but the picture shows 5 pins, missing the contact for the intermittent relay. Please call Cip1 and ask. I have a correct switch from them but can't find the correct listing now.
The external black wire is for the electric pump. No need to add an external switch and drill more holes. Take the pneumatic pipes off and reroute the tubes directly from the pump to the jets. If you want the intermittent relay, look for the same switch with 6 pins in the connector. The nice thing about the intermittent relay is that it will trigger your wipers for few seconds when you activate the pump. |
Literati914 Washer Stalk Question .. Jun 11 2019, 10:51 AM
SirAndy Also, is there an intermittent action (I doubt), a... Jun 11 2019, 11:28 AM
Literati914
Yes, there was an optional intermittent relay ... Jun 11 2019, 12:35 PM
SirAndy So, when adding this relay, how does your interact... Jun 11 2019, 12:48 PM
Literati914 Thanks Andy :beer2: Jun 11 2019, 02:00 PM
Valy Found it!
Take a look here for all the info yo... Jun 11 2019, 06:59 PM
porschetub I'am pretty sure I ran a spare wire for my pum... Jun 11 2019, 08:17 PM
Literati914
If you want the intermittent relay, look for t... Jun 12 2019, 03:02 PM
Valy There are 4, 5 and 6 pins versions.
I revisited ... Jun 12 2019, 04:36 PM
Literati914
[color=#FF9900]
[b]You want the 5 pins and t... Jun 12 2019, 10:27 PM
FlacaProductions So I'm looking at doing this conversion as wel... Jun 12 2019, 06:29 PM
Literati914
..I also was planning on using the Carmagic washe... Jun 12 2019, 10:25 PM
FlacaProductions What would be the corresponding turn signal switch... Jun 13 2019, 08:59 AM
Literati914
What would be the corresponding turn signal switc... Jun 13 2019, 11:42 AM
Literati914
What would be the corresponding turn signal switc... Jun 13 2019, 02:50 PM
FlacaProductions check this thread:
http://www.914world.com/bbs2/in... Jun 13 2019, 02:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th September 2026 - 03:18 PM |
