Oil pressure on a /6 under load |
SirAndy |
Jun 13 2019, 08:14 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What is the max oil pressure i should be comfortable with (under load) on my 3.6L?
I've been reading 993 manuals and posts all over the tinterwebs and all i can say for certain is that the stock 993 gauge seems to max out at 5 bar but according to all the info i found you'll get there already around 3k rpm and then the gauge just sits at max. The reason i'm asking is that i'm using a gauge showing psi instead of bar (with the correct sender for that) and 5 bar should be around 73 psi but my oil pressure is substantially above that under load. I'll idle around 40 psi (sometimes drops to 25-30 when it's really hot) and hit 100 psi as soon as i get above 3k rpm and pretty much stays there. I've seen as much as 110 psi. 100 psi is about 6.9 bar 110 psi is about 7.6 bar Question is, am i about to blow up my engine running these kinds of pressures? (IMG:style_emoticons/default/confused24.gif) |
jcd914 |
Jun 14 2019, 10:56 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
When did it start?
Didn't you have an oil pressure problem a while back? Something about a sudden loss of pressure? Or am I mis-remembering? Jim |
SirAndy |
Jun 15 2019, 12:33 AM
When did it start? Didn't you have an oil pressure problem a while back? Something about a sudden loss of pressure? Or am I mis-remembering? Yes, this is the inverse of my previous problem ... (IMG:style_emoticons/default/sad.gif) PS: I noticed it during the WCR trip |
Lo-Fi Version | Time is now: 6th June 2024 - 11:49 AM |
