Brake Peddle Play, Can one adjust this ? |
dralf |
Nov 30 2004, 01:40 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
I got my car off the jackstands this weekend and all I need now is to get some insurance so I can drive it down the road for a front end alignment. I have bleed the brakes a number of times and there is no air in the lines and the car stops OK, however there is about an inch or so of peddle travel before one can feel the master cylinder working or any sort of resistance. I plan on taking up the floorboard and looking at the linkage, but before I go doing that I wanted to ask some of you pros as to what kind of adjustments can I make to take up this free play. I read in the manual that there should be 0.1 MM ? of play in the MC plunger, but I think my free play is coming from something else. If I can figure out how to clear out my memory stick from my camera I will try to post some pictures now that it is all back in one peice. |
dralf |
Nov 30 2004, 02:25 PM
(IMG:style_emoticons/default/unsure.gif)
I just bleed the top bleeders ( I have speed bleeders in those locations) I have done it 3 times with the use of a power bleeded. Naturally I assumed that gravity / and density diffrences between brake fluid and air would be on my side and I only need to work the top screws. But as Scotty or was it Spock once said, " The Laws of Physics Do Not Apply" |
Lo-Fi Version | Time is now: 13th June 2024 - 02:40 PM |
