Beat the floors flat again, ..anyone had to ? |
Literati914 |
Jun 16 2019, 07:08 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
About to start my "quick resto" and am noticing now that carpets and noise tar are out, that the floors have some high areas (from running over stuff!). I swung a carpenter's hammer at it a few swings and the floors just laughed. I've got a 3lb hammer around somewhere that I'll try next..but getting a little dolly under it doesnt seem too helpful. Anyone got a better method?
Retroracer |
Jun 17 2019, 07:34 AM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Yes the 914 floors act like a polaroid for all abusive behavior to the car....!
I found a 9lb hammer used gently & sparingly helped a lot to get minor dents adjusted. Go slow and check with a straight edge often. - Tony |
Literati914 |
Jun 17 2019, 02:41 PM
Yes the 914 floors act like a polaroid for all abusive behavior to the car....! I found a 9lb hammer used gently & sparingly helped a lot to get minor dents adjusted. Go slow and check with a straight edge often. - Tony Got it Tony, thanks. This is PO damage BTW, same as, but slightly worse than what was done by the PO of my /6 conversion, years back. I was always a bit annoyed with the floors on that car - just knowing that they were uneven kinda bothered me the whole time. So, I'd like to correct these before putting it on the road. |
lierofox |
Jun 17 2019, 04:53 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Yes the 914 floors act like a polaroid for all abusive behavior to the car....! I found a 9lb hammer used gently & sparingly helped a lot to get minor dents adjusted. Go slow and check with a straight edge often. - Tony Got it Tony, thanks. This is PO damage BTW, same as, but slightly worse than what was done by the PO of my /6 conversion, years back. I was always a bit annoyed with the floors on that car - just knowing that they were uneven kinda bothered me the whole time. So, I'd like to correct these before putting it on the road. Trying to bend unsupported steel is surprisingly difficult, it just rebounds on you and it's like you're hitting it with a feather. You gotta support the immediate area around where you're trying to bend down from the other side. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:37 PM |
