> No Start Help Requested Please, 1975 1.8 L-Jet no start after 10 minute soak
rbzymek
post Jun 18 2019, 05:46 PM
So this is a conversion from a carb which was running great with the new FI. I had just installed an AFR meter and was adjusting the AFR to about 13:1 during a 30 minute run. Stopped at the grocery store and had a crank with no start after a 10 minute soak. The harness is newly fabricated, rebuilt AFM from AutoAtlanta, gas in the tank, I do have spark, fires with starting fluid, fuel pump runs when vane is moved, have power to the ECU, no difference with second ECU, voltage to the injectors with key on, new Pertronix III dizzy with Flamethrower III coil, have fuel pressure (40 psi), throttle switch doing what it is supposed to, AFM voltage output varies with movement, Air temp thermistor in AFM is in range, CHT reads 2.2 K ohms.
I'm kinda running out of ideas. Got any???? Thanks!
Ray
JeffBowlsby
post Jun 18 2019, 07:11 PM
40 psi fuel sounds high, did you verify that with factory specs?
rbzymek
post Jun 18 2019, 07:24 PM
QUOTE(JeffBowlsby @ Jun 18 2019, 07:11 PM) *
Jeff,
Thanks for responding. The spec is 35.7 psi. I guess that extra 4 psi could keep the injectors from opening after a hot soak which would increase the resistance and lower the current. I do have an adjustable regulator I will try. It's just strange that I could go from a great running engine to a no start. Thanks for the suggestion.
Ray
- Lo-Fi Version Time is now: 3rd July 2025 - 04:01 PM
