rbzymek |
Member ![]() ![]() Group: Members Posts: 199 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest ![]() ![]() |
So this is a conversion from a carb which was running great with the new FI. I had just installed an AFR meter and was adjusting the AFR to about 13:1 during a 30 minute run. Stopped at the grocery store and had a crank with no start after a 10 minute soak. The harness is newly fabricated, rebuilt AFM from AutoAtlanta, gas in the tank, I do have spark, fires with starting fluid, fuel pump runs when vane is moved, have power to the ECU, no difference with second ECU, voltage to the injectors with key on, new Pertronix III dizzy with Flamethrower III coil, have fuel pressure (40 psi), throttle switch doing what it is supposed to, AFM voltage output varies with movement, Air temp thermistor in AFM is in range, CHT reads 2.2 K ohms.
I'm kinda running out of ideas. Got any???? Thanks! Ray |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
maybe flooded with gas? did u try starting it while gas pedal all the way to the floor?
Lo-Fi Version | Time is now: 4th July 2025 - 12:28 AM |
