rbzymek |
Member ![]() ![]() Group: Members Posts: 199 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest ![]() ![]() |
So this is a conversion from a carb which was running great with the new FI. I had just installed an AFR meter and was adjusting the AFR to about 13:1 during a 30 minute run. Stopped at the grocery store and had a crank with no start after a 10 minute soak. The harness is newly fabricated, rebuilt AFM from AutoAtlanta, gas in the tank, I do have spark, fires with starting fluid, fuel pump runs when vane is moved, have power to the ECU, no difference with second ECU, voltage to the injectors with key on, new Pertronix III dizzy with Flamethrower III coil, have fuel pressure (40 psi), throttle switch doing what it is supposed to, AFM voltage output varies with movement, Air temp thermistor in AFM is in range, CHT reads 2.2 K ohms.
I'm kinda running out of ideas. Got any???? Thanks! Ray |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
finally Tim is here and he will definitely can help you Ray! His the best especially with ljet! Learned a lot from him on ljet system.
rbzymek |
rbzymek |
finally Tim is here and he will definitely can help you Ray! His the best especially with ljet! Learned a lot from him on ljet system. ndfrigi, Yes I did. I will take a closer look at the CHT sensor next. Ray The CHT reads about 2200 ohms at room temp which is normal. I pulled two injectors and cranked the engine. There was no fuel spray. I pulled the connector and probed both wires with a LED tester and there was no activity. So the module is not firing the injectors. The coil wire has continuity to pin 1 so it is getting a firing signal. What else besides the a CHT failure would cause the module not to fire the injectors?? I guess I will verify power and grounds to the module connector next. Ray |
Lo-Fi Version | Time is now: 4th July 2025 - 01:04 AM |
