Push Rod Tube Seal Leak |
collinvon |
Jun 19 2019, 02:27 PM
Newbie Group: Members Posts: 42 Joined: 11-June 19 From: St. Paul, Minnesota Member No.: 23,207 Region Association: Upper MidWest |
Looks like I found where all the oil has been coming from. I cleaned the engine as well as I could with a degreaser, ran it for 5 minutes at idle, and was able to spot a substantial leak coming out of the push rod tubes:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23207-1560976029.1.jpg) I'm going to tackle this project this weekend. I've found some good older articles that mention it can be done without dropping the engine, but might have to replace the seals on a couple without fully removing them. I'm going to replace the valve cover gaskets, adjust the valves for the first time, and I'll being doing the first oil change since I've had it. I've heard Valvoline ZR1 20W-50 is a good oil to use, and I can find it locally. Thoughts? Aside from ensuring I don't damage the seals on reinstallation, and thoroughly cleaning everything, anything else I should keep in mind, or try to tackle while I'm in there? Any other tips and tricks are much appreciated. Thanks in advance for any feedback. |
IronHillRestorations |
Jun 20 2019, 09:39 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It's pretty straightforward, just be sure to see how it's in there (pics prior to disassembly help) and make sure it goes back in correctly.
It's basically held in the slot on the rocker shaft bracket by spring pressure, and keeps pressure on the end of the tube. In doing my first rebuild a few years ago (35) I mistakenly trapped the spring under the rocker shaft bracket and was fortunate to find the problem before it killed my engine. |
collinvon |
Jun 20 2019, 09:46 AM
It's pretty straightforward, just be sure to see how it's in there (pics prior to disassembly help) and make sure it goes back in correctly. It's basically held in the slot on the rocker shaft bracket by spring pressure, and keeps pressure on the end of the tube. In doing my first rebuild a few years ago (35) I mistakenly trapped the spring under the rocker shaft bracket and was fortunate to find the problem before it killed my engine. Sounds good! Thanks again for all the info. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 02:58 PM |
