bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I rebuilt my Bosch 2.0L dizzy (p/n 039 905 205) but the vacuum canister is bad so I used a good one from a 1.7L dizzy I have on hand. The PET lists these as different part numbers and now I'm wondering if I need to track down the correct canister for this dizzy. Anyone know how much difference in advance between canisters and if it will make a difference? I'm going to be running Webers for now but may eventually restore the D-Jet and install.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,819 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
You'd be better off using a 1.8 distributor
bbrock |
You'd be better off using a 1.8 distributor I've read that the 1.8 is the preferred "stock" dizzy for carbs but my thought is to try one I already have first and if I have to buy a different dizzy, I will probably buy an SVDA for carbs. I've been curious why the 1.8 is better though. Does it have a better advance curve, or is it just because of the lack of injector triggers? I pulled my triggers and made a blanking plate for the hole. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1558413627.jpg) |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
You'd be better off using a 1.8 distributor I've read that the 1.8 is the preferred "stock" dizzy for carbs but my thought is to try one I already have first and if I have to buy a different dizzy, I will probably buy an SVDA for carbs. I've been curious why the 1.8 is better though. Does it have a better advance curve, or is it just because of the lack of injector triggers? I pulled my triggers and made a blanking plate for the hole. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1558413627.jpg) Get the 123 with bluetooth. Good luck. |
Lo-Fi Version | Time is now: 1st July 2025 - 02:33 PM |
