Opening driver's door from inside a bit difficult, Is it the door handle or the latch?? |
aylanco |
Nov 30 2004, 07:56 PM
Member Group: Members Posts: 106 Joined: 19-July 04 From: Ann Arbor, MI Member No.: 2,371 |
Hi All,
My driver's interior door handle has too much free play before it actually starts unlatching the door. The interior door handles open about 80 degrees total. My driver's door handle does not start to unlatch the door (ie pull the rod to move the latch) until about 60 degrees, which just does not feel right. The passenger door starts to unlatch the door at about 20 to 30 degrees, which feels normal. I pulled out the driver's door handle to inspect it. I am not sure what I am looking for, but the maze of parts making up the handle do seem to be a bit loose, and the cam actuating the movement of the rod does not make its contact until about 60 degrees of movement. Before I spend the $ on one part or the other, is it likely to be the interior handle or could the problem be with the latch. I know it could be both, bit I am wondering if this is a common thing from one or the other. Thanks |
URY914 |
Nov 30 2004, 10:17 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,001 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I believe the reason that the handles break is that over time the latch post become misalined with the "catch" of the door. This misalinement is from the car saging over time. If that post and door shift in thier relation to one another, it puts stress on the handle everytime you try to open it. Sooner or latter the weakest link breaks and which is the parts of the handle.
You can pick up handles on Ebay and the parts from Pelican. The photo above shows how I fix the mounting tab when it breaks. I've got a couple of inside handles if you need them. Paul |
Lo-Fi Version | Time is now: 5th June 2024 - 02:16 PM |
