vin question, two number plates missing |
drifter914 |
Jun 29 2019, 05:27 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi Guys... I bought a '74 914 with Indiana title showing the same vin as on the windshield frame tag & the tag riveted to passenger side front wheelwell. Both of these tags are easily replaceable.
The vin sticker inside driver door jamb is missing & the number stamped on top of pass. wheelwell has been ground off ... gone ! The number stamped inside rear trunk floor on pass. side is a different number & is only 7 digits. Should this number be the same as vin ? So... so do I have a vin swap situation here... ? I can understand maybe removing the sticker inside the driver door jamb for a repaint, but to grind off the number stamped into the metal on top of front pass. wheelwell seems very intentional & for what purpose ? Is the number stamped inside rear trunk floor supposed to match vin on title ? Not completely sure what I have here... possible vin swap ? I feel the number in rear trunk floor may be key to solution. (IMG:style_emoticons/default/confused24.gif) What say you ... Thanks... Terry in Az |
drifter914 |
Jul 1 2019, 07:45 AM
You guys are great ! Lots of very helpful info here.
I'm trying to keep an open mind about this, but so far cannot confirm one way or the other if its stolen with vin swap / vin swap from totaled car... or simply a replaced front pass. fender & missing Karmen plate & door jamb sticker. Dave... I sanded re-spray off of space on inner pass. fender where number should be stamped, right down thru grey primer to bare metal & can see no sign or trace of any numbers. This may very well be a replacement fender. Other than finding a vin under the dash, which is not readily apparent (haven't removed glove box & dropped fuse panel yet), I can think of no other way to confirm this is an original numbers car. Circumstantial evidence has never been absolute proof of fact. Yes... I did leave the 4 out of the vin, that number occasionally sticks on my laptop... probably popcorn or munchies crumb of some sort. Vin is 4742902235 Does that fall in the LE range ? Just fishing... Thanks youse guys ! Terry |
Lo-Fi Version | Time is now: 4th June 2024 - 02:42 PM |
